G35 & G37, Coupes & Sedans
help on how to run wires to door locks
Old Oct 29, 2008 | 05:45 PM
quicksolara's Avatar
hi i have a 2003 g35 coupe and putting a compustar alarm in it how do i run the wires to the door locks iin the drivers door.i cant get a spot to run them through the rubber boot because thee plug is blocking me am i missing something or is there a easier way to hook them up plz help cars all pulled apart and im stuck on how to get the wires ran to the switch.
Old Oct 30, 2008 | 12:11 PM
MidnightG35X's Avatar
As the republicans say, drill baby drill! I don't think there is an easier way to get into the cab of the car. A temporary solution is to run the wire underneath the weather stripping and then use some of the grommets that are in the door to connect to the switch. That is more of a testing solution, not a final solution.
Old Oct 30, 2008 | 08:09 PM
Curt G's Avatar
Forgive me if I'm wrong, but can't you just tap in to the wire under the dash? Sorry, I don't know what wire that is though.
Old Oct 30, 2008 | 09:03 PM
k ,what i did was i unplugged the plug which connects through the car ran the wire through the rubber sleeve and then removed the other side of the plug and ran the wires through then put the plug back and reconnected the other end of the plug again thanks for the help guys
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
