G35 & G37, Coupes & Sedans
Oil Consumption...HELP PLEASE!!
Old Oct 30, 2008 | 12:53 AM
bhancz's Avatar
i've got an 06' Coupe MT Stock and I know that it needs an engine replacement because I measure the oil consumption myself.
is there an advantage to waiting to get my engine replacement done now or should i wait a while??
also, is the engine replacement a brand new engine or a rebuilt one?
Old Oct 30, 2008 | 01:45 AM
Beebo's Avatar
Take it to your dealer let them run some test... if you have the oil consumption they will replace it with a NEW engine
Old Oct 30, 2008 | 09:31 AM
GR8TG35's Avatar
Like Wes stated, take it in to your dealer, and let them document the oil comsumption problem. They will most likely do the "Oil comsumption Test", by draining your oil, refilling and then monitoring the loss over time.
Odds are, if your losing a substantial amount of oil, say 1-2 quarts over a 3,000 mile period, your most likely getting a new engine.
Good luck
Old Oct 30, 2008 | 05:08 PM
OMG35S's Avatar
As everyone said take it to the dealer. You will go through a oil consumption test to determine how much you are consuming.
If replaced you will get a rebuilt engine not new.
Search is your friend..
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
