G35 & G37, Coupes & Sedans
2nd Break Change With In a year
Old Nov 5, 2008 | 04:56 PM
GRidah's Avatar
Ok so its time for me to change my breaks....AGAIN
Any1 here know why would the wear out so quick, i dont drive that fast, and deffinetly dont break hard last time i changed them was in january i believe at the dealership. Any suggestions????
Old Nov 5, 2008 | 04:57 PM
CrazyRuskie's Avatar
No clue. My brake pads didn't wear out that quickly.
Old Nov 5, 2008 | 04:58 PM
1SlowSedan's Avatar
You mean "brakes" not breaks.
Old Nov 5, 2008 | 05:11 PM
AllNatural's Avatar
marketing scheme from Nissan... use softer rotors to make them go under specs faster.
Old Nov 5, 2008 | 05:12 PM
AllNatural's Avatar
lol it also gives more bite to use softer rotors. But I feel it is in their part to make more money.
Old Nov 5, 2008 | 05:13 PM
AllNatural's Avatar
anyways what year you got? Brembo/nonbrembo?
Old Nov 5, 2008 | 06:33 PM
lambo09's Avatar
all i know is that the stock G35 brakes are severely inadequate.
to put it bluntly, they suck...they blow..theyre horrible.
as a result, you need to use the brakes more to accomplish
your intended goal of stopping or slowing, thus wearing out
the pads sooner.
so this doesnt surprise me that you have to replace them.
Old Nov 5, 2008 | 09:37 PM
Darkstar752's Avatar
the pads sooner.
Only the stock brakes of the 03-04 years. 05+ brakes went up in quality I believe because the are close to brembo specs.
Old Nov 6, 2008 | 03:49 PM
blazeplacid's Avatar
get aftermarket pads/rotors
you can actually get some great rotors for the same price as the dealer sells em
Old Nov 6, 2008 | 04:01 PM
gameovamuttz's Avatar
i agree garbage!! i just changed 4 months ago now they are already squeaking and i took them to get checked out and they are already about to that changing point.
Old Nov 6, 2008 | 09:38 PM
lambo09's Avatar
regardless....
its almost become a necessity to replace the brakes entirely upon
purchasing a G. =/
Old Nov 6, 2008 | 09:56 PM
regardless....
purchasing a G. =/
It's something I would do anyway. The pads are not that expensive to upgrade, and when your rotors go, you can either get new ones for 600 or whatever or buy drilled and slotted ones for 700.
Old Nov 8, 2008 | 01:01 PM
04NismoV35's Avatar
What year do you have?
The 03-04 (and 05x) brakes wore very quickly, however stopped very well.....the first couple of times. Then they would cook and fade easily. The 05-06 brakes (06 only on X) got a little bigger and went from 1-pot to 2-pot up front. Although they got close in size to the earlier Brembo option there was still no comparison as the calipers are far superior, not to mention the discs were thicker. Keep in mind, I state this in terms holding up after repeated stops or general thermal capacity. Altogether I feel the brakes all stopped pretty well.
Your best bet is to stop using oem parts and use better pads and Brembo blanks. If you tend to cook your brakes a bit then consider slotted or drilled rotors. I personally have been very happy with Axxiss ULT pad, although many here seem to prefer Hawks and others. Ultimately if those are still not good enough you can look into OE caliper upgrade or a full out swap.
Other things I did that made me very satisfied was stainless steel lines, Motul fluid, and a Stillen brake master stiffener.
Old Nov 8, 2008 | 01:37 PM
Mr.GEE's Avatar
20 Year Member
In 2003 & 2004, the non-Brembo factory brakes were so bad that Infiniti offered to extend the warranty on the pads and rotors to 36,000 miles or 3 years.
Old Nov 8, 2008 | 01:46 PM
04NismoV35's Avatar
That's right, I got 3 front and 2 rear replacements on my '04, but somehow they did not included the 05x which had the same brakes and I guess the Nissan 350z guys were probably out of luck too. Still, they stopped well, just wore WAY too quickly.
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
