G35 & G37, Coupes & Sedans
05 warranty question!!
Old Nov 12, 2008 | 01:50 PM
Trbulnt's Avatar
First off any and all help is greatly appreciated. I took my car in for a suspension thud in the front end of the vehicle after hitting a pot hole. The dealership told me that they "think" it the compression rod bushings have loosened up and that is causing my noise. I was informed that due to the pot hole the items are not covered under warranty and that the vehicle would need an alignment afterwards for a total cost of $535.00. Now my question is why wouldn't this be covered under the manufactures warranty. I told them about the pot hole incident and maybe I shouldnt have since they are using that as a leverage point against the warranty covering the damage. So my question is should I argue to have it warrantied or just suck it up and pay for it and hope that it fixes the noise? Thanks again.
Old Nov 12, 2008 | 01:57 PM
Otacon132's Avatar
id take it to another dealer, and not mention the pot hole incident, thats why they are charging you.
miltoda's Avatar
there is a service bulletin about compression rod bushings. Head over to infinitihelp.com and look it up. The thud/squeak/grinding sound is described in the bulletin. The pothole only help this badly designed bushing fail earlier than it already will.
Old Nov 12, 2008 | 02:19 PM
Trbulnt's Avatar
Thank you all for the fast help!!! I found the TSB and called the dealership back and I am now being taken care of under warranty.
johnadlertech
Brakes
Aug 31, 2015 02:03 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
