G35 & G37, Coupes & Sedans
03 navigation system: fuse? power supply?
Old Dec 13, 2008 | 02:23 PM
shakin's Avatar
My system won't load a disc and the screen doesn't turn on. I have a fuse tester and all the fuses under the dash by the driver's door are fine, but I figured there might be more fuses somewhere else. If not, is there a place to check the power connection for the navi system?
Thanks.
Old Dec 14, 2008 | 10:00 PM
dave's Avatar
You could get a copy of the service manual from over on the 350z Wiki. In the service manual, you will find the wiring diagram for the navigation system, and you may be able to track this down.
Also note that there are more fuse blocks. There is one behind the battery, and I think one other one as well. I'm sure if you search, you will find directions to find them.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
JLee301
Sep 25, 2015 08:46 PM
2014g35x
Sep 11, 2015 07:53 PM
zcherub
Sep 10, 2015 12:03 PM
