G35 & G37, Coupes & Sedans
My driveway is shoveled but my tires are still just spinning!
Old Dec 25, 2008 | 10:46 PM
Mr Inkredibul's Avatar
How the fvck do I get them to gain traction? This is my only car!
Old Dec 25, 2008 | 10:48 PM
eljoker's Avatar
dont step on the pedal that hard duh
your giving it to much throttle and its not catching grip
Old Dec 25, 2008 | 10:52 PM
^ Thanks but i definitely tried that first before I tried, putting salt infront of and behind all the tires. I also tried pieces of cardboard stuck underneath the tires (infront of and behind each tires) The tires spin and vdc cuts power. I've tried with vdc off as well. All times going really light on the pedal
Old Dec 25, 2008 | 10:54 PM
eljoker's Avatar
are you 6mt?
have you tryed a sandbag in the trunk?
Old Dec 25, 2008 | 10:55 PM
5AT no...i havent tried sandbags
Old Dec 25, 2008 | 11:10 PM
SiouxFallsG35's Avatar
Cat litter (non clumping?) is often recommended for getting cars out of stuck situations.
I'm assuming summer tires?
Old Dec 25, 2008 | 11:20 PM
speedracerg35's Avatar
if you don't have cat litter and want to get the car out, get a huge bucket of hot water and melt the ice around the rear wheels. the cat litter or sand around the wheels is a better idea though.
Old Dec 25, 2008 | 11:24 PM
I have Goodyear Eagle GT All-Seasons that were bought last winter (I'm back on OEM 17's for the winter)
Old Dec 25, 2008 | 11:25 PM
I'll try boiling water in the morning and then hopefully i can get the car out to buy some cat litter. I meant to buy some last winter
Old Dec 25, 2008 | 11:47 PM
jutn35's Avatar
G35 Coupe
Sand & Rock salt ?
Old Dec 26, 2008 | 12:09 AM
TXMAG's Avatar
An old 4x4 trick we used when we got stuck in the mud was to cut up a cheap carpet and wedge it under the tires.
Old Dec 26, 2008 | 01:28 AM
KsuMax's Avatar
put weight in your trunk; does wanders.
Old Dec 26, 2008 | 01:55 AM
Seymore's Avatar
Polar Ice Melt does the trick for me. Try and find the shaker gallon containers for ease of handling. Then I just refill the containers from bulk bags.
I'll bet you a buck my driveway is worse than yours.
Old Dec 26, 2008 | 10:25 AM
CreativeDesignZ's Avatar
i drove in 4 inches of snow on the parkway with bald all seasons, u can get out of ur driveway lol
Old Dec 26, 2008 | 01:18 PM
yourdoinitwrong's Avatar
Try ice melter and/or sand. Don't use rock salt because it is corrosive and could damage your driveway. I also don't think that boiling water is a very good idea because it may work for a few minutes but it's obviously cold where you live so it's just going to turn into ice again!
