G35 & G37, Coupes & Sedans
My driveway is shoveled but my tires are still just spinning!
Old Dec 26, 2008 | 01:50 PM
G35Now!'s Avatar
Moderation-free
Another old 4 x 4 trick in bad traction situations is to put the emergency brake on a bit - it stops the wheels from spinning as much. Note that it's a different effect than VDC, because there's no power cut involved.
Old Dec 26, 2008 | 02:09 PM
officerdbag's Avatar
DONT! use boiling water.. thats the dumbest thing u can do... that water is going to turn to ice and you'll bee stuck there for longer..
Also, don't sit there and spin out for long.. The heat from your tires will cause the snow to melt into water which will turn into ice again..
My trick is to slam it from reverse to drive really fast... you need to rock ur car back and forth..
I was in the same situation on an inclined driveway in my bro's SL500 mercedes.. it took forever to get up there.
Old Dec 27, 2008 | 12:35 AM
INFNTI's Avatar
Well, the first thing I've always heard is engaging the e-brake. The two things I know my dad used when he lived in the north was salt/sand and they had some old rugs that they would use to and apparently worked wonders.
Old Dec 27, 2008 | 12:29 PM
Mr Inkredibul's Avatar
Thanks guys I will remember this...luckily it was warm enough by the early evening that the ice melted enough for me to be able to chip it away and I got out!
chinee
Jun 10, 2024 07:48 PM
magnetism80
Feb 1, 2019 10:00 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
itschuckster
Jul 25, 2015 08:07 AM
