G35 & G37, Coupes & Sedans
Lock/Unlock transponder
Old Jan 2, 2009 | 03:12 PM
alphabetman's Avatar
I have an 03 G35 coupe. When i lock the car the lights flash but the horn does not honk. When i unlock the lights used to flash but they do not anymore. Any ideas ?
Old Jan 2, 2009 | 04:03 PM
jutn35's Avatar
G35 Coupe
Fuse out ?
Old Jan 2, 2009 | 04:16 PM
Which fuse ?
Old Jan 2, 2009 | 04:30 PM
Seymore's Avatar
Thought I remembered that you can cycle through the various unlock/lock indicator settings (Lights, horn, etc.) by pressing some combination of the buttons on the remote? Maybe you press both lock and unlock at the same time or something? If you search you can probably find it.
If you're car is still locking and unlocking remotely but the indications are just different than what they used to be, my guess is that you somehow advanced the settings to the next options by accidentally pressing the remote key combo.
Old Jan 2, 2009 | 04:37 PM
erklep's Avatar
just hold lock and unlock together till the horn beeps and then check it, you should have what youre looking for
Old Jan 2, 2009 | 04:39 PM
Mike_Deezy's Avatar
I remember pressing the lock button once the horn will not honk, but pressing it twice will. I'm not sure if the lights blinked when I unlocked it though. I've had my aftermarket alarm on my car for some time now and this is what I vaguely remember.
Old Jan 2, 2009 | 09:15 PM
GR8TG35's Avatar
You can program w/the key fob. Hold the two keys down at the same time and the sequence with change between beep and no beep.
SFLG35
Group Buys-Vendor
52
May 1, 2012 08:41 PM
SilverSedan
Jul 21, 2008 07:50 PM
