G35 & G37, Coupes & Sedans
Piping diameter question...
Old Jan 4, 2009 | 08:14 AM
flipboy326's Avatar
Will running a 2.5" magnaflow to a megan 3" y pipe outlet cause rasp???
I looked up y-pipe on http://www.350z-tech.com/zwiki/Y_Pipes and i got this
........"It is important to match pipe diameter of various exhaust components. A 3" y-pipe section dumping into a 2.5" rear exhaust section may cause undesirable sound (raspiness) and loss of power. "
seems like i answered my own question, but in looking at exhausts available and y pipes available.......a lot exhausts are 2.5 piping, and most aftermarket y-pipes have the 3" outlet that bolts to the exhaust pipe.
Any thoughts???
here's a picture
Old Jan 4, 2009 | 08:56 AM
Texasscout's Avatar
fIirst off, I would think that any system that didn't have a mid-pipe resonator would be raspy.
Second, will the 2.5" Manaflow bolt up to the 3" Y pipe without mods?
Old Jan 4, 2009 | 09:22 AM
dofu's Avatar
20 Year Member
It'll bolt up fine. It'll work fine, but not sure how great it would be to have a 3" to 2.5" piping. You can always have an exhaust shop weld in a reducer cone to smooth out the air flow.
Old Jan 4, 2009 | 10:55 AM
flipboy326's Avatar
do you think it would be easier to have the shop cut out the 3" section, and just weld on a 2.5" section?
I'm not quite sure how these things work, cause if you put on a cone, it would make one of the pipes longer, and then you'd have to cut the other pipe shorter???? like i said, i'm not quite sure how they work.
Old Jan 4, 2009 | 11:14 AM
dofu's Avatar
20 Year Member
By the looks of the exhaust set-up, I would just have a few inches of the midpipe cut to make space for the reducer cone.
Old Jan 4, 2009 | 09:46 PM
undefeated350gt's Avatar
Think of you exhaust system as a flowing drain system. lets say you want the most flow that you can possibly get, so you would want to match your piping as close as possible. You would actually loose power and gain alot of rasp, because imagine running on concrete and then trying to run on sand, thats what your exhaust flow will be like. Most people on this forum use full systems that keeps the piping diameter consistent.
Old Jan 5, 2009 | 07:43 AM
flipboy326's Avatar
well in that case, what is the diameter of our oem y pipe??? is it 2.5 all the way through, to even the outlet hole?
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
