G35 & G37, Coupes & Sedans
Please help, engine turns over, but won't start
Old Jan 6, 2009 | 11:12 PM
Heikes's Avatar
I just got the car back from a theft recovery (don't ask). The battery was missing, so I just replaced it. At first I had to re-program the factory keyless entry remote, but after finding out how to do that, the car still won't start. The horn also does not work, not when arming the car with the remote, nor when pushing the horn button on the steering wheel. The security light acts normal, except when trying to start the car, the light stays on constant. After some searching it sounds like the ivis/nats is active, but the remote is working to disarm and I have the original key. Is the horn part of the ivis/nats system? Yes, I checked the fuses. Any other ideas, or do I have to take it to the dealer on a flatbed?
Thanks in advance!
Old Jan 7, 2009 | 09:49 PM
maciejk's Avatar
i think its your immobalizer system
If Infiniti Vehicle Immobilizer System is malfunctioning,
this light will remain on while the
ignition key is in the ON position.
reset procedures
Restart the engine
using the following procedures:
1. Leave the ignition switch in the ON position
for approximately 5 seconds.
2. Turn the ignition switch to the OFF or LOCK
position and wait approximately 10 seconds.
3. Repeat step 1 and 2 again.
4. Restart the engine while holding the device
(which may have caused the interference)
separate from the registered Infiniti Vehicle
Immobilizer System key.
chinee
Jun 10, 2024 07:48 PM
Terry_G35
May 9, 2020 01:39 AM
andyg35c1
Aug 29, 2015 03:37 PM
D1dphresh
Aug 7, 2015 06:10 PM
Terry_G35
Aug 4, 2015 02:38 PM
