G35 & G37, Coupes & Sedans
Driver Side Power Window/Door Lock
Old Jan 16, 2009 | 11:33 PM
kleinr's Avatar
I have an 04 G35 coupe and something went out in my driver side door. The power window no longer works as well as the power door lock. I can however, open the passenger window and unlock the passenger door with the switches on the driver door and the keyless entry unlocks the passenger door. The driver door will only lock/unlock manually from the inside or with the key from the outside.
Has this happened to anyone else? Is there a fuse that needs to be switched maybe? I don't even know how to begin fixing this problem without paying an arm and a leg at a dealership....
Old Jan 17, 2009 | 09:30 AM
shakin's Avatar
Take it to an independent repair shop. It sounds like it's a simple problem (probably one part) and an independent shop will be a lot cheaper.
Old Jan 17, 2009 | 09:52 AM
g35man04's Avatar
CLUB MODERATOR
yes this happened on my 04 coupe but o the passenger side...Infiniti had to replace a relay or something like that to fix the issue.
Old Jan 17, 2009 | 09:53 AM
yourdoinitwrong's Avatar
Both issues are common problems with these cars. If you take it to a dealer it will be pricey to fix. If you do a search of the forum you will find some DIY's to fix the problems yourself.
Old Jan 17, 2009 | 09:54 AM
g35man04's Avatar
CLUB MODERATOR
I have a DIY to fix your window motor but not this other issue...
Old Jan 18, 2009 | 06:30 AM
Spedizzo's Avatar
Exact same thing happened to me. I am pretty sucky with DIY and out of warranty, has anyone else encountered this?
Old Jan 19, 2009 | 09:37 AM
kleinr's Avatar
anyone else have any input on this?
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
