G35 & G37, Coupes & Sedans
View Poll Results: Better Handles
350z
66.67%
G35
33.33%
Voters: 48. You may not vote on this poll
Whos got the better handles
Old Feb 21, 2009 | 10:19 AM
  #31
driftsucky's Avatar
yeah. I used to own a Z. Before I did all my do-dads to it, it wasn't a HUGE jump from the G unless you're on a track a lot. But, if you're at the track a lot, I wouldn't have the Z as your benchmark. You're shooting yourself short.
If you wanna handle like the Z, you'll have to reduce your wieght as well as upgrade your suspension. Sways and coils COULD bring you up to Z standards if you get the right set. But you'll still be heavier. So, you'll probably end up with a crappy DD ride to get to the Z or better.
Old Feb 21, 2009 | 04:33 PM
  #32
Ajax_Baltimore's Avatar
Word, hey, it's not just me who thinks the G35 is a better car overall than the Z! :P
2:22 - the suspension is better than a Z's
4:50 - a better car than the Z
And if you want the best handling, buy an STi for around the same price. But again, it's all up to the driver who will win in such a race.
Old Feb 21, 2009 | 04:51 PM
  #33
Skaterbasist's Avatar
Retired SuperMod
http://www.youtube.com/watch?v=rp3rWnF4n1Y
So you are actually being serious about this thread?
Ofcourse the 350Z handles better. It's lighter and has a shorter wheel base. There no question about it. It's not really something that's subject to debate.
In the other hand, the G35 almost handles as good. But at the end of the day, its still heavier and has a longer wheel base.
The 2005-2007 G35 Coupes with the sport suspension has the same spring rates as the Z. The only difference is about 150 lbs in weight and a shorter wheel base. Again, not a huge difference, but the Z will be a little more nimble.
Also, something to note is the fact that the Z has much stiffer spring rates than the Sedans. So when ever you hear someone complaining about how stiff it is, it's most likely coming from a sedan owner. My stock 06 Coupe 6MT was as "stiff" as the Z I test drove.
Since they aren't ages apart, a simple modification can always fix that issue for anyone.
You would think it would be common sense to assume that the sports car will have an edge on the luxury "sports" car (though its not a big difference)
OEM linear springs
G35 sedan's with non sport
Front: 283 Rear: 308
OEM linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
OEM linear springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006 (revised suspension)
Front:314 Rear:427
Old Feb 22, 2009 | 06:55 PM
  #34
on3_Lo35's Avatar
Kim Kardashian has better handles...
Old Feb 22, 2009 | 08:59 PM
  #35
spinna001's Avatar
Originally Posted by XBrisk202
this is G35 Driver
so my answer is the G is the best at everything compared to every car ever created
you are damn right sir
Old Feb 23, 2009 | 12:12 AM
  #36
Blackmouf's Avatar
Amen!!!!
Old Feb 23, 2009 | 01:55 AM
  #37
Red_G35's Avatar
^^ moar pics
Old Feb 23, 2009 | 02:50 PM
  #38
johnhanson007's Avatar
My friend's 84 sentra is also lighter and has a shorter wheelbase than a Z.
Ergo it has superior handles?
Old Feb 23, 2009 | 06:51 PM
  #39
driftsucky's Avatar
Were it to have the same suspension set-up, then yes. Given that it doesn't, then no. But you knew that didn't you? Yeah. You knew that.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
