G35 & G37, Coupes & Sedans
What does this warning display mean? (PIC)
Old Mar 25, 2009 | 07:48 PM
g352008silver's Avatar
This came on after I drove the G35 with both key fobs in my pocket (when I went to get a flat tire repaired).
Anyone know what this means? I mean, it lOOKS like it's saying the key fob battery is at...30%?
Old Mar 25, 2009 | 07:52 PM
OCG35's Avatar
means its f-ing cold outside, dont forget your jacket!
Old Mar 25, 2009 | 07:53 PM
UR2EZ's Avatar
do you have different seat settings for each fob? if so, it may have been confused on how to adjust your seat... just a guess
Old Mar 25, 2009 | 08:11 PM
Vrod-Mike's Avatar
It looks like it's telling you the battery life in the keyfob, but I can't say for sure since my 05 doesn't have that.
Old Mar 25, 2009 | 08:12 PM
jutn35's Avatar
G35 Coupe
Youre in Park
Old Mar 25, 2009 | 08:29 PM
uf20wop's Avatar
yeah
Old Mar 25, 2009 | 08:39 PM
g35man04's Avatar
CLUB MODERATOR
my thought is that your Keyfod battery is getting low...
Old Mar 25, 2009 | 08:46 PM
Jakemod's Avatar
^^^ Correct, its telling you that your key fob battery is low/about to run out. Replace the batteries on one or both of the key fobs if they both display that warning when you get in the car. It'll become obvious when you have to keep pushing the unlock button several times.
Old Mar 26, 2009 | 02:25 AM
Red_G35's Avatar
Pretty self explanatory lol
Battery is/getting low.
Old Mar 26, 2009 | 05:39 PM
keff108's Avatar
It means invest in a manual. Or if you have one check.
Old Mar 26, 2009 | 05:49 PM
eljoker's Avatar
just put the FOB in the slot to recharge it and your good to go
Old Mar 26, 2009 | 11:26 PM
Mustang5L5's Avatar
If my temp display read 47...i would crack the windows and open the sunroof
Old Mar 27, 2009 | 12:36 AM
OCG35's Avatar
I crank the heat to 90~
Old Mar 30, 2009 | 09:36 AM
Solekeeper's Avatar
You can charge a key-fob? I never knew this..
Old Mar 30, 2009 | 09:44 AM
JaxG's Avatar
The slot does NOT charge your fob. That is a myth. The slot is incase your fob battery does die, you put the fob in there to be able to start the car, but you can put it in there for as long as you want, and it wont charge it. Just buy a new battery for it.
