G35 & G37, Coupes & Sedans
Burning Smell
Old Mar 26, 2009 | 01:02 AM
smalls92's Avatar
Burning Smell
After I drive a litte hard or fast I notice this burning smell. Originally I thought it was my clutch because I am fairly new to driving a manual car. But then tonite I went out and did a little test. On an open street I opened up the car a little shifting hard up to 4th gear and then let myself coast to slow down and then lightly used the brakes. No smell. Then I did the same but at the end used the brakes hard to slow down and I would get this smell almost like burning rubber. So Im pretty sure its coming from the brakes now but my question is, what could be causing this? Do I need new pads? They have been squeaking but Ive been told thats normal on some brakes. Is it the rotors, calipers? Any advice would be great.
Old Mar 26, 2009 | 01:01 PM
BostonG6spd's Avatar
if they squeek, then you need new ones. go with OEM, cus Hawks produce waaay too much break dust
Old Apr 5, 2009 | 10:56 PM
smalls92's Avatar
Thanks for the advice.
I took it into the shop for a check up and they said that the brakes still had 90% left but they squeak because they are "low metallic" brakes and if I want brakes that dont squeak I need to buy some ceramic ones
Old Apr 6, 2009 | 09:12 AM
maciejk's Avatar
i switched to OEM and it stopped squealing, they also produce a lot of break dust
Old Apr 6, 2009 | 09:21 AM
Metalp3n's Avatar
thats pretty weird. I am running my Hawk HPS pads all around and I have noticed that they produce significantly less brake dust than any pad I have used to-date.
Old Apr 6, 2009 | 10:41 AM
InjectedPerformance's Avatar
Hawk pads should produce less brake dust. Had a set of Hawk HPS pads on my car it the dust was close to or less than stock. Follow the bed-in procedure and then go have some fun!
Blue Dream
Dec 5, 2015 10:56 AM
prinny
Nov 22, 2015 11:07 PM
Vqalexisz
Oct 14, 2015 12:48 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
