G35 & G37, Coupes & Sedans
matic-s and power steering fluid
Old Apr 13, 2009 | 08:18 PM
ab1's Avatar
ab1
So I grabbed the wrong bottle and accidentally put no more than 2oz of matic-j in my power steering fluid resevoir. I'm not sure that it matters much, since the power steering fluid calls for ATF. I was checking fluids and changing oil and it looked just a bit low so I wanted to top it off...wish I hadn't.
2007 G35x if it helps....
anyone have any input on this...
Old Apr 13, 2009 | 11:39 PM
insydiusg35's Avatar
You should contact your local Infiniti dealership to confirm. J-Matic is ATF from what I know...
Old Apr 14, 2009 | 11:30 AM
MidnightG35X's Avatar
You should be fine. The power steering calls for dexron III ATF, which might be the most generic type of ATF out there. Adding 2 oz of matic-J isn't going to hurt you.
Old Apr 14, 2009 | 12:08 PM
ab1's Avatar
ab1
^^ That was my assumption too...thanks for some piece of mind.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
Kicknshift
Sep 3, 2015 09:35 AM
PZ06G
Interior
Aug 24, 2015 06:27 PM
