G35 & G37, Coupes & Sedans
Will over tighten driver cause engine to loose power?
Old Apr 20, 2009 | 10:59 PM
LudwigB's Avatar
I just had the drive belts replace about a month ago. Initially the tension was a bit loose and the belts would squeal at start up especially during cold weather. I then took the car back to have the tension tightened. But now I felt like the engine doesn't rev quite freely as before. The engine feels a little bit high strung.
So do you think if the drive belts (and ac belts) tension a bit tight, it will rob the engine some power?
Old Apr 20, 2009 | 11:42 PM
Beebo's Avatar
they need some slack...
Old Apr 21, 2009 | 06:10 AM
makaveli06's Avatar
if the belts are too tight they'll tear or crack a lot faster
Old Apr 21, 2009 | 09:02 PM
Curt G's Avatar
No, not enough that you could ever notice.
Old Apr 21, 2009 | 09:23 PM
Mustang5L5's Avatar
Belts that are too tight could also cause bearings in some of the accessories to fail sooner due to the added stress places on them by side loading.
Old Apr 21, 2009 | 09:41 PM
insydiusg35's Avatar
Belts need some slack; too tight could cause premature failure.
Old Apr 22, 2009 | 01:38 PM
LudwigB's Avatar
Just curious, how do we know if the tension is about right or too tight or too loose? Is there a way to find out?
Old Apr 22, 2009 | 01:48 PM
Mustang5L5's Avatar
There is usually a spec measured with a belt tension tool. The tension tool pulls the belt slightly with a preset load and the deflection of the belt is measured.
I don't know what the spec is for the G35 however. Someone else will need to look it up.
IIRC, Autozone rents one
They look similar to this
Old Apr 22, 2009 | 01:49 PM
uf20wop's Avatar
there's a belt tension gauge, but it's like 100 bucks
Old Apr 22, 2009 | 05:40 PM
Mustang5L5's Avatar
You can find them cheaper than that
vmcarbuyer
Oct 12, 2019 12:42 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
will091195
Jul 27, 2015 09:19 PM
