G35 & G37, Coupes & Sedans
2 problems with my lovely car CC
Old May 6, 2009 | 03:33 AM
Hanoon's Avatar
I have 03 sedan G35 and I love it and recently i see two issues
1- The cruise control light come on but it won't set all the time (some time it set and work perfect ) some times it just wont respond to set button.
2- In the early morning i hear squeazing noise (sounds like a belt) screaming for a min then it goes away by itself.
Please advice
Old May 6, 2009 | 04:58 AM
Darqfallen's Avatar
Cruse could be a wiring issue, it sounds like a loose wire.
The belt noise, check your fluids, perhaps power steering fluid, perhaps it your water pump, or ac belt.
Good luck.
Old May 6, 2009 | 07:10 PM
afmafia's Avatar
you need new belts riverside nissan has them for like 36 shipped or you can get them from your dealer for 45.
Old May 9, 2009 | 06:47 AM
Hanoon's Avatar
Thank you guys for help.. I got the set to work ok now after I just pulled back the break pad one time ,,,
the other problem for the belt sound only hapopen in the early morning when i first turn the car on other than that it wont do this noise.
Old May 9, 2009 | 01:17 PM
pwebb's Avatar
you can try tightening the belts.
loosen 2 14mm bolts for pulleys - dont take them out, just back off a few turns
adjusters are 12mm. one is at an angle, use a swivel.
tighten the 14mm
dont crank down too hard, just give it a bit more tension. a few turns should do.
if they are visibly cracked and dry, get new ones. belts are easy to do.
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
wonderizm
Sep 24, 2015 03:09 AM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
