G35 & G37, Coupes & Sedans
Put 240/45s on the front...Is this okay?
Old May 18, 2009 | 11:14 AM
familyman333's Avatar
Originally Posted by conesweeper
Yes it's possible. I'm currently running 245/35/19 on all corners. Front wheel is 8" wide and rear is 8.5". Now, I have no idea if it will affect vdc on the coupes since they came standard with staggered tire set up from factory, but my sedan worked fine with the oem coupe size tires and my current set up.
Since the wheels are different sizes does that mean you cannot rotate?
Old May 18, 2009 | 06:00 PM
orl-g's Avatar
You cannot rotate wheels front to back only side to side.
I think you could probably put same size tires on all four, rear wheels are only half inch wider the front wheels. you might have "stretched" looked tho.
personally i think 245/40 and 255/40 is the only way to go on oem 19's, you will be sticky as heck i guarantee it.
Old May 18, 2009 | 06:20 PM
PPGFREAK's Avatar
1) Every wheel and tire combo has been asked and tried on here. Im not saying it to be a jerk but if you type in what sizes your thinking about in the "search" you will find thread after thread on what your asking about. It will help you find what your looking for fast then hopping some one knows the info you need.
2)Every tire out there has a list of rim sizes you can mount them on.
3)Check this site with what size you have and what size your thinking about and it will tell you how much wider,taller,lower it will be. http://www.bigcustomwheels.com/info_specs.jsp
Hope some of this helps
Thebaws11
Nov 30, 2016 12:54 PM
NJ6MT
Sep 10, 2015 08:40 AM
jbmw002
Sep 10, 2015 12:54 AM
mikemf8
Sep 3, 2015 08:01 PM
