G35 & G37, Coupes & Sedans
Coupes Tires?
Old Jun 14, 2009 | 12:00 PM
AaronJP's Avatar
Coupes Tires?
Ok so I have a G35 coupe. I noticed todays my rear tires seem to be loosing tread depth, but its more in the middle than the edges... Is that normal? The outside edges seem to have more tread depth left. If if helps tires as only lasted about 20-25k miles.... May be able to make another 5k... Any insight would be helpful.
Old Jun 14, 2009 | 12:04 PM
Allshow's Avatar
are your tires over inflated? thats a pretty good life on the tires. ive read about people only getting 12-15k miles. also how bad are the tires with tread to the wear bars? if you have a tire depth gauge 2/32 you really should change the tire.
Old Jun 14, 2009 | 02:26 PM
pwebb's Avatar
I see the middle wear out quickly on the coupes, on all types of tires.
Old Jun 14, 2009 | 07:47 PM
gary c's Avatar
Your tires shouldn't be inflated for more than 35 to 37 PSI or you will wear out the centers of your tires. If you look at what it tells you on the drivers door jam Nissan/Infiniti recommends 35 PSI, it's a good idea to believe them since they built the car....also it rides better using the correct tire pressue.... On the sidewall of your tires it give a maximum tire pressure, that has
nothing to do with what you should be running! (35PSI)
Gary
Old Jun 14, 2009 | 09:48 PM
Missile558's Avatar
Gary
+1 and it's always good to check the tire pressure for long drives and change of weather.
Old Jun 15, 2009 | 01:13 AM
BuckeyeInMI's Avatar
Mileage on your tires is very dependent on the driving style and the tires themselves. I'd be quite upset if I only got 25K on a set of Michelin Pilot Sport A/S because they have a 45,000 mile rating. But if I got 15K out of some Bridgestone RE050's I'd be thrilled.
If you're worn past 2/32" then it's time to replace them. If you live in a dry climate, you can stretch that a little bit, but they will become more and more dangerous to drive in wet weather the longer you wait.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
jjohns2711
Aug 5, 2015 08:58 AM
brian_z
Jul 29, 2015 05:08 PM
itschuckster
Jul 25, 2015 08:07 AM
