G35 & G37, Coupes & Sedans
Need 20+ HP from an intake- willing to spend
Old Jun 15, 2009 | 07:55 AM
jjbart16's Avatar
my coupes got the stock 280 and i just want 300HP at least
what air intake can i get that will boost me up to 300 or better
im willing to spend, just need ideas
Old Jun 15, 2009 | 07:59 AM
JOKER's Avatar
CLUB MODERATOR
your stock coupe got less then 240 hp to the wheels
there is no intake in the world that will get you to 300hp.
You are going to need boost to get to those numbers.
Old Jun 15, 2009 | 08:01 AM
Vic07G35's Avatar
Vortech supercharger
Old Jun 15, 2009 | 08:06 AM
JOKER's Avatar
CLUB MODERATOR
oooooooooor
Stuff your intake pipe full of these
and you got your self a 300hp G35
if you want to go more then that then you can also stuff you exhaust pipe full of those that will create an afterburner effect and give you well over 400hp at high RPMs
if you do that you would probably want to cote your rear bumper with some heat shield material cuz you'll have all them flames shooting out of your pipes. Also put a warning sign on your rear window for other cars not to drive to close to you cuz of the flaimzzzz shooting out and ****.
Old Jun 15, 2009 | 08:20 AM
G_whip's Avatar
Lol^
Old Jun 15, 2009 | 08:26 AM
Vrod-Mike's Avatar
Well considering the fact that he has 287HP at the crank 300 isn't so far away.
An intake won't get you there, but get yourself a MD 5/16 spacer and an MREV2 and that will put you where you want to be.
Old Jun 15, 2009 | 08:33 AM
JBF's Avatar
JBF
Take a leaf blower and hook it up to your intake but make sure you hardwire the leaf blower in to the car so when you drive off, you dont unplug it.
Old Jun 15, 2009 | 08:36 AM
G_whip's Avatar
^ rotfl look that up on you tube it works kinda
Old Jun 15, 2009 | 08:40 AM
GreenGoblin's Avatar
The goblin resurrection
That is an inflated number from the factory, and if you are chasing a number then that is fine. Usable power is the key, not a dyno number.
Old Jun 15, 2009 | 09:03 AM
CUZ's Avatar
CUZ
Originally Posted by JOKER
oooooooooor
lmao
Old Jun 15, 2009 | 09:26 AM
twin001's Avatar
How are you, or are you going to measure actual gains from the intake? You are going to be awfully upset when you see the dyno numbers.
if I were you, I would get the MREV, spacer, and Osiris. This should get you well over 20 hp/tq throughout the powerband.
Old Jun 15, 2009 | 09:43 AM
seung012's Avatar
TT or SC..... intake = maybe 4-6whp.....
Old Jun 15, 2009 | 09:58 AM
eurodre's Avatar
lol 20hp from an intake, thats a good one
Old Jun 15, 2009 | 10:18 AM
gary c's Avatar
Two words came to mind when I read this thread, "Wishful Thinking!" Although many manufactures will claim large increases in HP from their intakes it's quite/most often not true.... What you need to achieve your goals is a Vortech supercharger, cost installed $5K+ then you will have surpassed your 300 HP.
Gary
Old Jun 15, 2009 | 10:21 AM
tragedycat's Avatar
lol you must be new.
Buy every bolt-on you can, get a tune, and you'll get around there. NA is a long and expensive road with very little payoff. FI is an even more expensive road but at least there is a light at the end of the tunnel.
