G35 & G37, Coupes & Sedans
Leak on passenger side
Old Jul 6, 2009 | 12:54 AM
PublicEnemy's Avatar
I noticed a leak yesterday on the passenger side near the front tire, actually directly behind the tire.
It's not oil, antifreeze, brake fluid, clutch fluid.
Both my girlfriends parents have Nissan's. I asked them and they said it's probably the drain port for the A/C and that it's just water leaking out. Normal for most Nissans (as the port is normally located behind the passenger's side front tire)
I wanted to make sure, see what you guys thought?
Old Jul 6, 2009 | 07:08 AM
Blue Dream's Avatar
I drove ttrank's car solo
Yup. that's what it is. Nothing to worry about. If it isn't draining on a regular basis, then you have a problem.
Old Jul 6, 2009 | 04:17 PM
SteveAZG's Avatar
yep my car leaks right there on a regular basis, being that I'm out in Arizona where the AC is on full blast most of the time, its a regular occurance for me...
Old Jul 6, 2009 | 09:41 PM
Osa713's Avatar
same here..
Old Jul 8, 2009 | 07:01 PM
OCG35's Avatar
If its clear and odorless, its just condensation from the AC – every car does that… if you see fluid when the AC has not been running, its something else – but then it would be colored and have an odor (engine coolant, ATF, oil)…
Old Jul 9, 2009 | 05:33 PM
Mustang5L5's Avatar
Same here. A/C condensation runoff.
And every summer someone always freaks out when you are driving on a humid day and water is pouring out of the car from that port.
Old Jul 9, 2009 | 09:48 PM
Hehe, Thanks guys.
I guess all the drain ports on my prior cars weren't so close to the side, or I never noticed.
Old Jun 26, 2024 | 03:56 PM
Joy@646's Avatar
Coupe
My son's 2006 G35
My son's G35 started leaking behind the front passenger tire as well. But when he cranked it up, it started smoking and smelled like burnt plastic, or possibly rubber. Is the smell similar? We just replaced the entire cooling system, though. Any thoughts on what this could be?
So over fixing this car already.
Old Jun 27, 2024 | 01:29 AM
pistonheads's Avatar
Black obsidian colour, gas engine, and manual transmission
Have you considered using a UV dye in the water to trace the leak? It's a bit messy but can help pinpoint where it's coming from. just an idea if you're still stuck.
mbe093
Lights
Oct 2, 2016 11:09 PM
brane123
Interior
Aug 23, 2015 06:55 AM
RA081024
Aug 18, 2015 07:03 AM
wylin
Lights
Jul 18, 2015 06:12 PM
