G35 & G37, Coupes & Sedans
castrol syntec >> mobil 1 v.withUOA
Old Jul 14, 2009 | 03:55 PM
  #46
Deepdiver's Avatar
^the 25 qts in my garage all say european formula..
Old Apr 27, 2010 | 01:05 PM
  #47
VVFive's Avatar
Originally Posted by uf20wop
same exact driving conditions, driving to and from work about 20 miles each way, 15 of that highway driving. and a lot of city driving on the weekends. redline it probably every few days.
castrol syntec is the report of the left and mobil is the report on the right
the syntec was run for 5200 miles and the mobil 1 only 3750.
i don't think i'll ever be using m1 again.
wish someone could do the comparisons with the AMSOIL synthetic oil too......AMSOIL's claim of 12000 miles without an oil change has always sounded too good to be true .....
Wish some stats could throw light and prove me wrong.........
Old Apr 27, 2010 | 01:48 PM
  #48
jibberjabbers's Avatar
The Mobil 1 guys must be pissed. They have been pushing for M1 and saying it's the best Motor Oil for the G (over the counter oil)...
Old Apr 27, 2010 | 03:52 PM
  #49
joedaddy1's Avatar
most synthetics can last 12~15k.
Old Apr 27, 2010 | 03:59 PM
  #50
Sure it can 'last', but is it safe? I mean all the crap that is collected from the motor... Oil help removes impurities from the motor. After a certain thousand miles, I don't care how long oil "last". It's stops providing protection when all that crap is collected and moving about the system.
When oil "looks" dirty, that means it's doing it's job (removing impurities from the motor and providing lube...
Get dino or synthetic blend and Change it every 3700..
Old Apr 27, 2010 | 04:10 PM
  #51
Jeff92se's Avatar
Red Card Crew
You run w/o a filter or something?
Old Apr 27, 2010 | 04:17 PM
  #52
12k on the same filter? If it's an OEM filter, I bet the cardboard has deteriorated and bits and pieces is flowing all over the place. If not, its probably clogged up by now and restricting oil flow.
Ever tried changing the filter w/o changing the oil? lol PITA.. I mean, if you're going to do all that, might as well change the oil too.
Old Apr 27, 2010 | 04:19 PM
  #53
Swivel's Avatar
Moderator
^^ Yup, not that difficult.
Old Apr 27, 2010 | 04:22 PM
  #54
Must of been messy azz hell...
Old Apr 27, 2010 | 04:27 PM
  #55
Jeff92se's Avatar
Red Card Crew
I believe the engine block features a check valve that prevents the oil from draining when you take the filter off.
The oil's job is to keep harmful particles suspended so it doesn't hurt the motor. Big particles are taken out by the filter.
If you keep oil's TBN number up and do a filter change, you can run SOME synthetics for a long time.
enter long haul diesel trucks here.
Old Apr 27, 2010 | 04:30 PM
  #56
Swivel's Avatar
Moderator
Exactly, it doesn't leak much at all. I was running Amsoil synth on an extended drain interval and changed the filter halfway through. Unfortunately my cheap, lazy azz didn't get a UOA.
Old Apr 27, 2010 | 05:09 PM
  #57
yogi41's Avatar
On my350z pennzoil platinum did really well on the non-revup engines. I would be curious to see the comparison between pennzoil platinum and castrol synthec.
Old Apr 28, 2010 | 09:42 AM
  #58
blazeplacid's Avatar
can someone explain to me why you would want German castrol??
I think some people buy into marketing to much.
My dad had a 92 chevy truck and only used the cheap oil. Im talking back when it was like $6.99 for a filter and oil cheap. That truck had 225,xxx miles when it was sold and never had a problem at all. I dont even know the name of the oils, but I know he didnt pay to much or use synthetics. No leaks, no problems, the truck is still working today.
He just changed the oil every 5K on dino juice.
I use both back and forth (castrol/mobil1) which ever is on sale with a filter at the time.
Old Apr 28, 2010 | 12:58 PM
  #59
K Dub's Avatar
They shouldn't really be pissed....
More like embarrassed now that it has been shown they didn't have a clue what they were talking about all along.
I'm glad this forum is getting more educated on the whole Mobil 1 issue. Simply put, it's really not that good of an oil, and no way in hell is it worth the price you pay for it.
10-15 years ago things were different. These days, it's nothing special. Might as well use whatever you can find for $2/qt. at Wal Mart instead of using Mobil 1.
Old Apr 28, 2010 | 01:00 PM
  #60
K Dub's Avatar
My reasoning for it comes only from the UOA's that I have had done for my cars and the others that I have seen done as well.
GC > Regular Castrol Synth > M1
Every time.
You just can't argue with the numbers.
mbe32
Nov 13, 2015 11:09 PM
MrIP35
Oct 25, 2015 11:13 PM
CV35Driver
Sep 15, 2015 05:09 PM
