G35 & G37, Coupes & Sedans
I have a Question for all members!
Old Sep 9, 2009 | 08:30 PM
Phantoms's Avatar
I'm no doctor, but why does a head injury give you a desire to write and type in orange?
And your reading just about every other post on the forum in black any way.
Old Sep 9, 2009 | 08:33 PM
mjgonegm's Avatar
Originally Posted by OCG35
pull the staples out - maybe you'll be able to type in black.
Not time yet andif i pulled them out it might not end so well, lets get back on topic
Old Sep 9, 2009 | 08:44 PM
PublicEnemy's Avatar
Originally Posted by mjgonegm
You won't with proper aiming, but iirc most of the non Factory HID's have projectors. and besides the factory use to do on some cars that just used a glare shield on the bulb
There is a reason halogen bulbs are put into reflector housing. HID bulbs produce insane amounts of glare when put into reflector housing with NO CUT OFF to prevent others from being blinded.
You can aim all you want, you're still blinding everyone else.
Old Sep 9, 2009 | 09:00 PM
mjgonegm's Avatar
Why are you still arguing this? it does not even apply to G's
But in either case Hid's and certain housings can work and FAIL big time, but to say you will will blind everyone is a blank statement.
And I don't think you understand ''cut-off'' Every headlamp has an cut-off, Projector however produce the best cut-off and light beam.
HID's in reflector housings can work without blinding everyone with tweaking, i have installed them in cars many times, and in my two personal cars. one with projectors and one with reflectors.
Infact let me show you a picture...... Which is which?
Old Sep 9, 2009 | 09:21 PM
Exactly. You see that fading upward? That's blinding everyone else. There's a reason they are illegal to install. I say "blinding everyone", because you are. Halogen reflector housing is designed for, wow, you guessed it, halogen bulbs. You posted two pictures, one showing either reflector housing with an HID bulb, or the cheapest projector crap ever known to man. The second picture you posted was a waste of bandwidth.
Of course I understand "cut-off", it's self-explanatory. It is where the light "CUTS OFF". Halogen reflector housing does not cut off the light output, it is (in most cars) simply aimed downward and the light disapates.
And the "doesn't even apply to Gs?" Why are you offering a group buy, for HIDs, on a G35 forum then?
I reiterate my previous point, if you don't have projectors in your headlight housing, don't blind the rest of the world with HIDs. Be considerate of others on the road.
Old Sep 9, 2009 | 09:37 PM
mjgonegm's Avatar
I said it wasn't perfect but it provides a decent cutoff not to blind people, and in that picture the car is higher than the street. Next it won't blind people unless they directly coming toward you. if you look on either side of the beam there is a dip to prevent that. A second picture ??
Of course I understand "cut-off", it's self-explanatory. It is where the light "CUTS OFF". Halogen reflector housing does not cut off the light output, it is (in most cars) simply aimed downward and the light dissipates.
The G35's are headlights are designed for them
I'm sure if i was i would have been flashed or pulled over hundreds of times
read in the quote
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
pxlds
Jul 30, 2015 01:31 PM
mushu
Jul 15, 2015 03:55 PM
