G35 & G37, Coupes & Sedans
Motor mounts broken need some help
Old Sep 10, 2009 | 11:00 AM
jalonzo43's Avatar
One of my motor mounts is broken, so i need to replace them. Does anyone have any suggestions on which ones i should get or should I just buy stock ones? I need to replace them soon cuz you could hear thumping sounds when I accelerate or make sharp turns so if there's anyone that could help me out id appreciate it....
Old Sep 10, 2009 | 11:06 AM
DaveB's Avatar
Go with OEM mounts. Aftermarket ones with introduce a lot NVH. Are you sure that a mount is broken?
Old Sep 10, 2009 | 11:21 AM
jalonzo43's Avatar
yeah I got a new clutch on my car and the mechanic said my left one was cracked...I've also been hearing noises from my engine when I accelerate quick and make sharp turns....Ok thanks for your help
Old Sep 10, 2009 | 04:04 PM
OCG35's Avatar
broken motor mount??? Unless you are putting downs TONS of power, I'm baffled that one broke
Old Sep 10, 2009 | 05:42 PM
jalonzo43's Avatar
I dont know how it happened but that's what the mechanic told me...I dont know what else it could be that's making that thumping noise. It's prity loud, I just didn't know if I should go with the oem or some other ones...
Old Sep 10, 2009 | 05:59 PM
OCG35's Avatar
OEM are liquid filled for low-no vibration - most/all after market are solid mounts that will introduce more vibration but transfer more energy to wheels...
OEM would be your best bet... solid mounts are for high hp cars (usually track cars).
Old Sep 10, 2009 | 06:34 PM
jalonzo43's Avatar
Ok thanks for your help...
magnetism80
Feb 1, 2019 10:00 AM
alessandro
Oct 8, 2015 09:29 AM
Claudiu
Sep 26, 2015 01:04 PM
master111
Sep 25, 2015 08:32 PM
