G35 & G37, Coupes & Sedans
My G35 is feeling a little bit sluggish
Old Oct 29, 2009 | 12:11 AM
atn_chargers's Avatar
I've notice over the past couple of month that my G is losing it's UMPHH. It feels as though it has loss some power. Most noticeable is the loss of sound in the exhaust note. It doesn't roar like it use to. What could be the culprit of this issue? My car is an '06 with 37k miles on it. What would you guys suggest? Fuel service? Tune up? Any suggestions?
Old Oct 29, 2009 | 01:31 AM
VictoriousG's Avatar
A TT would give it a little more umphh as you put it
Old Oct 29, 2009 | 01:35 AM
TIAN's Avatar
Hold The Line
Air leaks in the exhaust? Maybe a blown gasket
Old Oct 29, 2009 | 01:42 AM
I'm not sure what the problem is. It might be my conservative driving habits that the ECU picked up. I'm going the try to reset the ECU and see what happens. After that, oil change, new air filter, and hope for the best.
Old Oct 29, 2009 | 02:10 AM
Blittzz's Avatar
I dont think that year had the algorithms ECU... id get it check for air leaks as Tian mentioned.. or it could be your airflow sensor.. had that before after a service and it wasn't put back properly..
Old Oct 29, 2009 | 02:25 AM
Airflow sensor could affect the performance? I will get the car checked for air leaks as well.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
itschuckster
Jul 25, 2015 08:07 AM
laksjd84
Jul 24, 2015 05:12 PM
