G35 & G37, Coupes & Sedans
Best color for brake caliper?
Old Nov 6, 2009 | 01:20 PM
gary c's Avatar
Since you have a black car I'd go with black. Use high heat paint and make sure they're very clean before painting. You might even paint the calipers where the rust forms above the lugs. Use lots of paper and blue tape and paint inside a garage, over spray can be a PIA!
Gary
Old Nov 6, 2009 | 01:22 PM
4DGS's Avatar
OCG killin' another thread whorin' out his car!
To what Gary said, I masked off my whole fender with paper when I did mine.
Old Nov 6, 2009 | 01:23 PM
OCG35's Avatar
Originally Posted by gary c
Since you have a black car I'd go with black. Use high heat paint and make sure they're very clean before painting. You might even paint the rotors where the rust forms above the lugs. Use lots of paper and blue tape and paint inside a garage, over spray can be a PIA!
Gary
fixed
Old Nov 6, 2009 | 01:27 PM
OCG35's Avatar
what????? I hope you're kidding - I don't need a color of caliper thread to post pics of my car ~
I was showing the guy that black OEM calipers makes sense because they are hidden and less visible. BBK makes sense to paint. It was pics of the wheels not even the car
Old Nov 6, 2009 | 01:30 PM
4DGS's Avatar
And damn fine wheels they are lol
Of course I was kidding.
Old Nov 7, 2009 | 09:00 PM
Mustang5L5's Avatar
I painted mine silver. I did the rotor as well. They were originally silver anyway, so i wanted them to look clean and new. I think it did the job perfectly. It even matches the wheel color.
I prefer the clean, subtle look.
Old Nov 9, 2009 | 12:45 AM
JoeSage's Avatar
rotors look very nice. I like that a lot. how did u paint them silver? just same paint as calipers? and did u get rid of that dirt protector around ur roter? looks like theres none there
Old Nov 9, 2009 | 08:19 AM
Mustang5L5's Avatar
It's Duplicolor caliper paint. They sell spray and brush on versions. I used the spray. I took everything apart and painted the rotors off the car as well as the caliper pad bracket.
For the caliper, i hung it in the wheel well, wrapped garbage bags around everything and the car and sprayed it so i didn't have to disconnect the line. Then i let dry for an hour and reassembled.
Forgot to add, i prepped with brake cleaner, a wire wheel on a drill for thr rotors, and then some simple green and water to clean, and vinegar to etch prior to paint.
Still looks that good to this day, need to do the rears still.
I didn't remove the dust shield. It's behind the rotor.
Old Nov 11, 2009 | 06:58 PM
playatl's Avatar
Red is a good color to choose!
Old Nov 14, 2009 | 12:41 PM
1SIIIKG's Avatar
Brake n caliper color..
Depends on the color of your car.....red looks **** check out my Stop Tech Big Break set up on my Peal White beauty!!!!!!!!!!!
Old Nov 14, 2009 | 09:58 PM
johnhanson007's Avatar
Originally Posted by blkonblkGsedan
i did black with red infiniti decals, don't do red IMO unless is on a BBC, i had red and i changed my mind, did black and im happy now
gross
Old Nov 15, 2009 | 04:43 AM
4DGS's Avatar
Billionaire boys club?
Old Nov 15, 2009 | 03:37 PM
NjMatteSedan's Avatar
Originally Posted by johnhanson007
gross
you were probably looking at yourself in the mirror while you were typing that
Old Nov 16, 2009 | 04:36 PM
1SIIIKG's Avatar
Hater!!!!!!!!!!!
gross
"hahahaha" good stuff another hater bites the dust it's not my fault I'm paid!!!...keep it up I am always looking for more haters....if I wasn't I'd probally start to think that I was slippn...
Old Nov 16, 2009 | 06:54 PM
  #30
EnerOnE's Avatar
do sliver
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
kinetek
Aug 3, 2015 04:25 PM
Harman Singh
2nd Gen (V36) Sedan
Jul 30, 2015 03:39 PM
mushu
Jul 15, 2015 03:55 PM
