G35 & G37, Coupes & Sedans
my g35 lotus elise... exige
Old Nov 28, 2009 | 11:03 PM
HwyDrftr's Avatar
Here's a good write up, 3050 lbs is what this guy ended up with without getting crazy, still a few hundred pounds to shed if you wanted to replace the dash, strip the interior and get rid of the A/C, heh. http://www.6mt.net/forum/racing/1559...g35-coupe.html
at 3050lbs your looking at a power to weight that is about the same as a N/A Elise.
Old Nov 28, 2009 | 11:09 PM
HwyDrftr's Avatar
Originally Posted by marcinr
HwyDrftr, I agree that it's definitely possible to build a G to keep up with an Elise, but the absolute limit of a <2000lb car with a low polar moment of inertia due to mid-engine is quite a bit higher than a 3500lb nose heavy car. A better G driver can certainly take a slightly less experienced Elise driver on the track, but skill being equal, the Elise is going to be faster. A couple of weeks ago, I was driving my Elise on the track, and I got totally schooled by a guy driving a 2004 G, but he was using slicks, I had comp tires, and he was a more experienced driver.
Agreed, but a G out on the track making time with the sports cars is a beautiful sight
Old Nov 29, 2009 | 12:26 AM
infinitisport's Avatar
thank you hwydrftr - that's what i was waiting for - awesome info link -
project time i think for the winter...
Old Nov 29, 2009 | 12:56 AM
yea - after the reading i see some problems - not enough weight reduction and too much money for it
i already have the spare and tools, battery plenum covers, floormats, and battery (replacement) out... that's not even 100lbs yet...
Old Nov 29, 2009 | 01:25 AM
marcinr's Avatar
20 Year Member
Infinitisport, before you start cutting weight out of the car, get the other parts that are making the car slow fixed first. You would be surprised how well you can do with some dedicated track wheels with R compound slicks, a good suspension, and good brakes. Once you've made those changes, the best money spent is actually driving the car and mastering your skills to keep it at the limit. Only once the car starts to hold you back, does it make sense to start ripping it apart into a race car.
Old Nov 29, 2009 | 01:41 AM
4DGS's Avatar
Buy lighter wheels, take out your backseat, gut the trunk, you don't need any of that junk anyways.
There's probably about 120 pounds (depending on wheels) and it still looks and feels like a normal car from outside and the front seat.
Old Nov 29, 2009 | 02:41 AM
thescreensavers's Avatar
Mr.202?
A Lotus Elise/ Exige are both very oriented cars, the inside looks like it does for a reason. Weight savings.
Old Nov 29, 2009 | 03:45 PM
for wheels and tires i have volk 19 with sumitomo summer ultra high performance - excellent investment - can't agree more...
but the suspension and other stuff is complicated so i don't do them hence that's why i just wanna demod rather than modding it...
it's the same thing and better... imagine riding a motorcyle... light and very responsive despite small horsepower... so that's what the elise is all about... can't do that with 3000lbs tho
Old Nov 29, 2009 | 04:26 PM
4DGS's Avatar
What volks? No pics? You know the rules here....
Old Nov 29, 2009 | 04:46 PM
binder's Avatar
sharif from forged stripped down a new 370 z and without anything in the interior i think it was down in teh 2800's. So you need to add seats, dash, gauges......driveable and not a metal chassis you are probably not going to sit under 3000lbs. That is also removing all the comfort items so the car will look unfinished and will not be comfortable. engine size and body dimensions are vastly different from an elise which is why we have the weight.
Old Nov 29, 2009 | 05:04 PM
Texasscout's Avatar
they are two different philosophies of car. You can't turn one into the other, I wouldn't even try. The Lotus is a "go-kart" because it IS a go-kart, just a big one... with a top... and AC (that sucks btw). The G is a "car".
Old Nov 29, 2009 | 05:40 PM
i have pic of the sf challange volks on my car somewher i'll post later check page1...
yea, i hear y'all - ain't getting it under 3k lbs is what im hearing...
i still plan on the rear seat going tho and like 4dgs said about the trunk... out too...
Old Nov 29, 2009 | 06:07 PM
Texasscout's Avatar
I took the rear seat out of my sedan once. It was less than ten pounds. It's all foam and leather. (and thin leather at that.) The lower section just pops out, you can hold it up with your pinky finger.
Old Nov 29, 2009 | 06:55 PM
dead weight aka NVH - dampers???
saw this on some review about dead weight - could not find it on my coupe???
anybody???
here's the review partial exerp:
Closer inspection proved this something was visible from both sides. In this detail shot you can see exactly what I'm talking about: dead weight -- about 1.4 pounds (22.16 ounces) of it per side. Bolted to both of the G35's mufflers is the below weight:
attachment below
ps - the rear seats is somewhere between 10-40lbs, depend on who's weighing it????
Old Nov 30, 2009 | 01:00 PM
  #30
binder's Avatar
look, a 2 seater Z is barely getting down to 3k lbs so you can remove all the seats you want, it still won't get lower than that.
and that "dead weight" attached to the exhaust has already been removed on those cars since they use lighter aftermarket exhaust systems. Trust me, the racing built stripped cars are done by people that know every last lb they can pull off.
