'07 G35 broken into.. how to disable auto window roll down??
hymnn, either disconnect the lock assembly
and be SOL when your battery dies, or somehow make the alarm go off when doors are open with the key not with the remote
some of you are missing the point...
if i understand correctly what the OP is stating is that they are not using the screw driver to turn the tumbler and engaging the roll down. they removing the shroud and somehow grounding/triggering the roll down.
and also yes there is more to deter a thief but with such and easy way to open the door, by disabling it you'll just keep an honest person honest...
Shatter a window and it's pretty freaking obvious what's going on.
wow NJ sucks.... no offense
http://myg37.com/forums/g37-coupe/18...in-too-nj.html
http://www.freshalloy.com/forums/arc.../t-105539.html
I actually had that happen to me while I was at AMC watching a movie. I came out to see that my key hole cover was missing. Funny thing is though, I had nothing visible in the car and everything inside the car is stock. No headunit, nothing. Come to think of it, I had nothing in the car at all since I just detailed the interior. LOL. They didn't get into my car, so I figured maybe they just stole the key hole cover cause that small piece is worth $40 itself. Still though, pretty scary thought. =\
But hey, why me? I'm stock and there were 3-5 other G35's in the same structure.
At least they didn't jack ur stock corner and the wiring harness connected to it.
Infinti wanted 1000+ to replace the entire wire harness because they didn't sell just the corner socket....
Luckily my insurance covered it. And I made sure they replaced the entire harness instead of splicing and taping. My car was just a week old when some ricer raped my car.
Yep the wiring harness is 1peice. So if someone jacks ur socket, u need to replace the entire thing, or go to a junkyard and cut off the wires you need.
There weren't many G35's in the junk yard at the time. And for a new car, I wanted it to be repaired correctly.
One word Viper!! You can also have the system connected to your Iphone/ cell.
Viper can be setup so if anyone get's near your car and starts to touch it" will beep at them and you will get am MSM sent to your phone.
Your looking at about $1200 installed with all the options but your get what you pay for!
http://www.viper.com/
http://www.viper.com/P-5902V/Viper-5...e-Start-System
http://www.viper.com/ShopViperProduc...tegoryCode=106
http://www.viper.com/SmartStart/Demo.aspx
Main System
Viper 5902 Responder HD Color SuperCode SST 2-Way Security and Remote Start System $799.99
Accessories
Audio Glass Break Sensor $39.99
Digital Tilt Motion Sensor $79.99
Backup Battery System $69.99
2-Way Garage Door Interface $229.99
Backup Battery Siren $79.99
Viper Electro-Luminescent Indicator $29.99
Programmable Voice System $199.99
Window Automation System $149.99
Interface Module
$99.00
Main System
Accessories
Interface Module
$99.00
