G35 & G37, Coupes & Sedans
Car turning off
Old Dec 16, 2009 | 01:40 PM
oldguiser's Avatar
Car turning off
I have a 2003 G35 sedan, I have had it for 2 1/2 years now and about a month ago it started turning off. It use to only turn off after it had been running and the engine was at the regular temperature. But lately it has been trying to turn of when I'm trying to warm up the car. Any ideas why this is happening? I have checked the engine oil and it is normal. Could it be the transmission oil? Please help!!!
Old Dec 16, 2009 | 02:14 PM
blazeplacid's Avatar
highly unlikely, but maybe water in the gas??? you can use Heet to get some of the water out
How long has the problem been occurring??
Does it only want to die when idle?? Possible vacuum leak?
Old Dec 16, 2009 | 02:21 PM
LightsOut's Avatar
SIETESG
two other threads all based on sedans shutting off. problem was thorttle body.
Old Dec 21, 2009 | 11:44 AM
That1Guy's Avatar
TPS (throttle position sensor) or MAS (mass air flow sensor) maybe? Try spraying some MAS cleaner (buy at auto parts store....dries faster than carburator cleaner) and see if it helps......couldn't hurt for an inexpensive attempt.
Good luck.
Old Dec 21, 2009 | 01:10 PM
nghiars's Avatar
MAF sensor is bad.
starts perfectly fine if your car hasnt been running for a while right?
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
ddietz97
Jul 26, 2015 06:16 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
