G35 & G37, Coupes & Sedans
VDC, Slip, Tire Pressure, & Brake Light all on and wont go away! HELP!!
Old Feb 10, 2010 | 11:35 PM
sk8bo4rdv's Avatar
hey guys so recently my VDC, Slip, Tire Pressure, & Brake Light all turned on and they wont go away. i want to ask you guys that may have had this problem before what i can do to get these lights to go away. would replacing brake pads and rotors make a difference since mine are worn if not close to being worn out. i do need an oil change as well. what would explain the tire pressure light and slip? i have no idea i need help!!!
Calvin's Avatar
Overglorified Altima
brakes explain the vdc, slip, and brake lights. check your fluids and pads.
low tire pressure explains...the low tire pressure light.
Old Feb 10, 2010 | 11:39 PM
Neu Era's Avatar
dont think we have a wear sensor on our pads though. did you try disconnecting you battery?
Old Feb 10, 2010 | 11:46 PM
Calvin's Avatar
low brake fluid is the most common cause of vdc, slip, and brake lights going on at once.
low tire pressure light is caused by _______________. fill in the blank.
Old Feb 10, 2010 | 11:53 PM
Neu Era's Avatar
hmm never ne lo brake fluid caused that in our cars. thanks for the info calvin.
Old Feb 10, 2010 | 11:57 PM
sk8bo4rdv's Avatar
ok thanks calvin. ill check my fluids. i need to replace pads and rotors so tat will be done soon.
and as for low tire pressure, whats it supposed to be at so i know for reference.
sk8bo4rdv's Avatar
i will try that right now. and see how that goes
Old Feb 10, 2010 | 11:58 PM
Calvin's Avatar
it should say on the sticker in the door jam.
Old Feb 11, 2010 | 12:00 AM
Neu Era's Avatar
33 all around. supposed to be 30, but i put an extra 3 for cold weather.
Old Feb 11, 2010 | 12:01 AM
Calvin's Avatar
<---36 measured cold (before being driven on) on 245/35/19 275/35/19
Old Feb 11, 2010 | 12:04 AM
sk8bo4rdv's Avatar
cool ill check it out tomorrow morning. ill disconnect the battery and se ehow that goes and check the fluids. im having lots of road noise as well. time for new shocks and springs as well since ive been low for a while now on stock shocks they might be close to blown. time for coilovers
mike730
Jan 12, 2018 04:25 PM
wojowojo16
Jul 27, 2015 09:57 AM
Lsantana757
Jul 20, 2015 09:08 AM
papo020
Jul 17, 2015 10:30 PM
