G35 & G37, Coupes & Sedans
How to remove gauge cluster
Old Feb 25, 2010 | 09:23 PM
itsgroll's Avatar
I just purchased my G last month and for some weird reason there looks like there is moisture or fog inside the cluster close to the trip reset button. So i need to remove the plastic and clean that up.....its driving me crazy looking at it.
Is there a DIY on removing it? Thanks
Old Feb 26, 2010 | 03:00 PM
gary c's Avatar
If you've done a SEARCH and can't find what you need check with www.infinitihelp.com. There's a ton of information on that site....
Gary
Old Feb 27, 2010 | 01:34 PM
VictoriousG's Avatar
Try the tech area.
Old Feb 28, 2010 | 03:32 PM
wannascooby's Avatar
let's see... If I can remember how I removed mine out of an 04 coupe
Removed the screws from the steering column (philips and there are a few), Had two 10mm bolts on the bottom that you need to use an extention on. Remove the turn signal and windshield wiper things. Remove a few more screws that you see and then yank and pull. Haha, I don't think this will help much, but if you're like me you'll figure it out once you take it apart
Old Mar 1, 2010 | 12:49 AM
itsgroll's Avatar
my fault i was lazy and didnt search. I found what i needed. But thanks for your help
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
9tray turbo
Sep 29, 2015 10:22 PM
wow600rr
Sep 28, 2015 11:50 AM
