Do i need to remove my door Panel?
So i was changing all of my interior lights to white LEDS. while changing the light on the buttom of the door the bulb slipped out of my finger and fell inside of the damn panel!!
Now when i drive i hear the damn thing rolling back and forth inside the door panel. MY questions is do i need to removed to the door panel or can i just pull the clips out from the bottom of the door? if i pull the clips will the bulb fall out? i have a Gcoupe btw.
I tried this and just scratched my hand up. Ill give it another try... IF you guys say i can just pry the door from the bottom then ill give that a shot aswell aslong as i dnt break anything
You only have to remove three screws to properly pry up the lower half of your door. (I wouldn't bother un-clipping any wires for what you need though)
https://g35driver.com/forums/body-in...l-removal.html
If you don't.. just make sure you don't pry the bottom too much, as to break/crack the upper door.
Danielek
May 1, 2022 01:28 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
