G35 & G37, Coupes & Sedans
Will 295/30/20 fit?
Old Apr 16, 2010 | 11:52 AM
DEEZBLUBALLZ's Avatar
Will 295/30/20 fit?
I'm looking at buying a set of 20" wheels with an offset of +25.
20X8.5 +25
20X10.5 +25
Will a 295/30/20 fit in the rear of my coupe? It isn't lowered, fenders are not rolled. Worried about it chewing tires on the rear.
Thanks guys.
Old Apr 16, 2010 | 12:07 PM
Silencer_0's Avatar
Why so big? Don't plan on lowering it?
Old Apr 16, 2010 | 12:40 PM
I do want to lower it in the very near future. I don't want to do any aggressive fitment on my G. Just want the widest tire possible. looks bad *** + 295/30/20 from General Tire costs a lot less than all the 285/30/20 tires I was looking at.
Old Apr 16, 2010 | 01:21 PM
gary c's Avatar
BlueballZ, well alright...you can use the 295s but visually there's not a major difference between 285s and 295s. When you lower your G you may need to have your fenders rolled depending on how looooooow you go....
Gary
Old Apr 16, 2010 | 01:28 PM
G2FLIP4's Avatar
everything
Im running a 285/30/20 with 25 offset. If you plan on lowering it you WILL need to roll or cut off the fender lip. Im running -2 degrees of camber in the rear and Im just clearing the fender(cut off my lip). Youre definitely gonna cut up some sidewalls with a 295
Old Apr 16, 2010 | 01:30 PM
Thanks Gary C.
G2FLIP4
I will have to roll the rear then. What if I wanted to run a 305 section width in the rear...lol? Is +25 on a 10.5" wide rear wheel enough to clear the rear lowered with just rolling the fender?
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
dseet
Oct 11, 2015 12:40 AM
Claudiu
Sep 26, 2015 01:04 PM
