G35 & G37, Coupes & Sedans
Acceleration Issue
Old Apr 20, 2010 | 04:08 PM
spm725's Avatar
Unhappy Acceleration Issue
I was driving down the freeway last week, and an WRX flew past me. When I floored my car, It started to Skip. Kinda Like it's Surging.. Any news on what this would be? Alternator? Battery? Mechanical?
Old Apr 20, 2010 | 04:11 PM
Hotdawwgman's Avatar
engine could be pulling timing... What mods do you have?
Old Apr 20, 2010 | 04:16 PM
spm725's Avatar
I just barley added an Intake. Other then that I dropped my CAT.??
Old Apr 20, 2010 | 11:14 PM
g35dp's Avatar
What kind of intake? Sounds like your engine not getting enough fresh air; maybe an air leak.
Old Apr 20, 2010 | 11:17 PM
jibberjabbers's Avatar
Sounds like you have an automatic. Flooring it sometimes, the car will lag. Maybe you should just shift into manual mode....
When I had an automatic, and floored it, the car would lag. I had to lightly tap it 1st, then floor it... Then the car would take off. (car would downshift)...
Same with a manual car. If I floor it, it would go no where. I would have to downshift to make it go.
Old Apr 20, 2010 | 11:22 PM
thescreensavers's Avatar
Mr.202?
If you floor the 5at in D mode it will down shift to the lowest gear possible, and will not have skipping issues, It would lag a bit reading your input then down shifting, but its not that bad
Old Apr 21, 2010 | 02:10 AM
What do you mean by you dropping your cat?
Old Apr 21, 2010 | 02:15 AM
spm725's Avatar
no cat. on my exhaust. And its just a Short Ram. Yeah I have the 5 sd sport shift. It has done it before when I had it in tip too, and I just hope its nothing major.
Old Apr 21, 2010 | 02:39 AM
Tabris's Avatar
Might sound stupid, just trying to help.. but it isn't related to wheel skip in anyway is it? I know I've jammed the gas a couple times and had the wheels jump before taking off (once really badly in my old Prelude). Or is it in any way related to old tires without grip? (the tires can't put the power down to the ground sufficiently?)
Old Apr 21, 2010 | 10:25 AM
BlkCoupe's Avatar
That is normal for the 5AT. I used to describe it as the car felt like it was winding up and then would leap forward. There are two solutions a SprintBooster or a valve body kit for the transmission. I personnaly have been running a SprintBooster for over a year now and am very pleased with it. It will remove the hesistation between shifts when in auto mode. In Manumatic mode it makes the shifts super quick with minimal rpm drop.
Old Apr 21, 2010 | 02:09 PM
kvangil's Avatar
Your car didn't wanna play with the WRX. Seriously though, considering that we don't know the condition of the road/tires/weather, perhaps just your VDC in action before your car slips?
Old Apr 21, 2010 | 02:41 PM
Simple fix is floor it (TWICE). Do it real quick. It worked on my previous AT cars.
Floor it once and it will do nothing, let go and floor it again and it will take off. You have to play with it a little to get it right.
Old Apr 22, 2010 | 04:30 AM
spm725's Avatar
Yeah I have brand new wheels and tires. It was dry haha. And thanks guys im gonna look into that sprintbooster. To make matters worse I blew a tire on the freeway tonight :[ tg my rims are okay tho!!
Hasanbaloch
Feb 29, 2024 08:45 PM
Dat Kid
Nov 23, 2015 11:18 AM
cmesidewayz
Sep 29, 2015 09:28 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
joedaddy1
Jul 28, 2015 02:58 PM
