G35 & G37, Coupes & Sedans
broken mount...
Old Apr 20, 2010 | 04:36 PM
3rick35c's Avatar
Under Construction
broken mount...
So I broke 2 parts on my Gee... part 1- right rear end link and PART 2- THE MOUNT WHICH THE RIGHT REAR END LINK ATTACHES TO. ITS THE PART THAT IS OPPOSITE TO THE REAR SWAY BAR... I called rick from riverside infinity i hope he can pull through on the mount (part #2) i will post pic of whats involoved.
Old Apr 20, 2010 | 04:37 PM
3rick35c's Avatar
Under Construction
unless if anyone has a totalled Gee i would love the MOunT from one....
Old Apr 20, 2010 | 11:16 PM
g35dp's Avatar
Wow, that sucks. Did you hit the curb? Good luck.
Old Apr 21, 2010 | 12:36 AM
gary c's Avatar
Are you refering to the sway bar end links? It's not uncommon for those to break, several member here have had the same issue....easy to replace.
Gary
Old Apr 21, 2010 | 01:38 AM
3rick35c's Avatar
Under Construction
no its the actual mounting plate that is bolted onto the frame of the car...if you have a sec look at where your endlink is mounted on your car... its not where the endlink is attached to the sway bar its the other part the the other side the endlink attaches to
Old Apr 21, 2010 | 09:36 AM
3rick35c's Avatar
Under Construction
sorry its kinda blurry it was taken by my i phone but you can still see the broken part...
magnetism80
Feb 1, 2019 10:00 AM
jeffbdye
Jun 1, 2018 03:51 PM
itgogitrev
Sep 23, 2015 07:08 PM
