G35 & G37, Coupes & Sedans
Do i need Camber Kits?
Old May 1, 2010 | 09:12 PM
07_Gcoupe's Avatar
Im planning on dropping my 07 Coupe on Eibach Pro Kit. Would i need Camber kits aswell? Who is dropped without Camber kits and how has it been with tire wear? Thanks
Old May 1, 2010 | 09:31 PM
taylordio's Avatar
yup
Old May 1, 2010 | 09:39 PM
pinkii's Avatar
I dont have a camber kit but want one with some bigger spacers in the front
I have firestone firehawks all weather tires on mine and havent noticed much wear.
Old May 2, 2010 | 12:18 AM
gary c's Avatar
Depending on how many miles you've driven you will notice the inside edges wearing on both back and front tires. If you installed springs you should have had your alignment done, what did the alignment sheet show and how far from OE specs were you? These are all things you should have discussed with the alignment mechanic. It's relatively simple, if you lower your G35 you'll need the camber kit. If you drive what most people do a year, say 10K miles you'll be buying tires frequently without it....your choice.
Gary
Old May 2, 2010 | 01:44 PM
silver g's Avatar
Yeah get a camber kit. I had an Eibach Pro kit on my car a long time ago and my camber and tire wear was $hit. Camber kits make it much better!
On a side note, I would save up and go for coilovers! Forget the springs they suck anyway IMO. As soon as I went with coils it was a night and day difference. My .02.
Old May 3, 2010 | 01:02 AM
ZE120's Avatar
quote if i am wrong, but the rule of thumb is a drop more 1.5+ inches would warrant a camber kit.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
jsimonk
Steering & Suspension
Sep 2, 2015 03:07 PM
