G35 & G37, Coupes & Sedans
keyfob battery question
Old May 6, 2010 | 04:53 PM
saywat?'s Avatar
if i dont use the second keyfob should i take the battery out? im jus thinking like most electronics if u dont use it the battery will start to leak and discharge and cause build up on the terminals. and if i do remove the battery itll lose the program right?
Old May 6, 2010 | 08:37 PM
dave's Avatar
I think the car is programmed, not the fob.
Old May 6, 2010 | 08:42 PM
saywat?'s Avatar
^^yea but the fob grabs the program code from the car and stores it on the fob? or thats not how it works?
Old May 6, 2010 | 09:13 PM
Silencer_0's Avatar
What programming are you talking about? You won't lose anything from replacing the batteries. The only times I've seen batteries leak were on electronics that had the batteries for over 8 years.
Old May 6, 2010 | 09:16 PM
saywat?'s Avatar
^^how does a key fob tell a particular vehicle to un/lock its door? from the program code set on the keyfob from the vehicle right or no?
well i have an 03 and i doubt the second keyfobs been used much. and now that im the new owner the second keyfob will def not be used. so i wanted to be safe and remove the battery permanently from the keyfob not being used cus i dont want the batt to leak if left in there.
Old May 6, 2010 | 09:25 PM
Silencer_0's Avatar
Oh, that. Well the programming isn't stored on the batteries. I'm sure it's stored on some memory module inside. Think of it this way, if you unplug a computer, you hard drive doesn't get wiped out, right?
I replaced the battery in my key fob a while ago, nothing changed.
Old May 6, 2010 | 09:39 PM
saywat?'s Avatar
^^but isnt the memory module staying alive becus of the battery? so if remove itll lose its memory? u do kno computers have alittle coin battery inside to keep the memory settings right?
Old May 6, 2010 | 09:46 PM
Silencer_0's Avatar
Yes, I do know about the battery on the motherboard for the bios settings. Like I said about the example with the hard drive, although you cut off it's power supply, all your data is still intact and continues exactly where you left off.
Old May 6, 2010 | 09:48 PM
saywat?'s Avatar
^^i understand ur computer example but the keyfob may not work the same. who knows maybe it works the same as a bios
Old May 6, 2010 | 09:50 PM
erklep's Avatar
if you replace the battery, you wont lose the program. but the OP is asking about taking it out for a long period of time. yes, it will lose the program if you take the battery out ans store it. its a simple procedure to reprogram though. can be done in 15 seconds
Old May 6, 2010 | 09:53 PM
Silencer_0's Avatar
I know. I know because I've changed my battery personally, along with endless other people who've had no ill effects from changing their battery.
I don't blame you for being skeptical, I'm no Nissan engineer after all. I think your best bet would be to call your Nissan/Infiniti dealer and ask them.
Old May 6, 2010 | 09:57 PM
saywat?'s Avatar
my god! finally one person who understood wat im asking. i was starting to get frustrated lol thank u erklep! lol
chinee
Jun 10, 2024 07:48 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
mtlruss
Dec 20, 2015 01:51 PM
Hawk196
Sep 22, 2015 02:51 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
