G35 & G37, Coupes & Sedans
04 G35 Coupe Bose System
Old May 12, 2010 | 06:26 PM
MrMagallon's Avatar
Seems that a wire or two may be loose because when i hit a bump my tweeter on the left side turns off and then also a speaker in the back, does anyone know how the wires are ran so that i can just check to see if the wires are loose to fix it myself instead of paying a butt load to get it looked at?
Old May 13, 2010 | 06:29 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
Try posting in the A/V section.
Old May 18, 2010 | 04:10 PM
onthe3rdday's Avatar
There isnt a cable loose. There is a ribbon cable in the Bose radio that allows the CD player to communicate w/ the amp. Think of an older style computer ribbon cable. It's seated poorly. The problem you are experiencing should only be happening when you use the CD Player, if it happens with the radio or tape player then it's a seperate problem. It's a $700 Dealer fix w/ radio replacement or if you are feeling adventurous you can open up the radio and fix it on your own. I'll link the DIY when I get a chance
mjfenix
Aug 17, 2017 05:49 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
BlackGee35
Jul 21, 2015 07:24 PM
vstypicals
Jul 20, 2015 10:55 PM
