View Poll Results: Motordyne or Hotchkis Sways?
Motordyne
61.54%
Hotchkis (New Version)
38.46%
Voters: 13. You may not vote on this poll
Quote:
Gary
+1 Def.. i could care less if my sways were powdercoated Barbie Vette Pink.. as long as they perform to my expectations...thats why im leaning toward the MD sways.. (solid Construction)... my only Neg ( and reason for this thread is that not many people have posted about them as they have hotchkis) i tend to rely much more on customer reviews than sellers. Dont get me wrong i have not a bad thing to say about MD ( on the contrary always quality products) but it looks like im gonna have to be a guinea pig here..lmao. And with the Hotchkis i know the only issue they had has been corrected..Originally Posted by gary c
I'm using SPC adjustable endlinks, that and some thread locker my suspension is super tight. They're easy to install and adjust, couldn't ask for anything better....If you'll notice in the install thread the sways used aren't adjustable, what a waste! Who buys endlink for how they look? Should buy them for strenth/adjustability....
Gary
Silencer_0
close
- Join DateDec 2008
- LocationCorona, SoCal
iTrader Positive Feedback100
iTrader Feedback Score(25)
Liked:264 Times in 147 Posts
^ if you're looking for reviews on the motordyne sways (including mine), just look up the official motordyne sways thread.
17 post's in this thread and no one bring up what matters most. You have so many bar choices and since so many of them make questionable stiffness vs oem claims, it should come down to one thing. Bar specs, Do not bother with stiffness claims. Only one I trust is EVO350 and those specs were only made public as part of a discussion, never used as marketing.
Solid construcition vs hollow. Bar strength is a fuction of diameter and lever arm distance (where you put the end link holes). In hollow bars, this applies as well in addition to wall thickness. Just because a bar set is hollow, does not mean a thinner solid bar can out leverage it.
Beebo
close
- Join DateDec 2006
- LocationEl Paso Texas
iTrader Positive Feedback98
iTrader Feedback Score(59)
Liked:205 Times in 182 Posts
MotorDyne sways with Powergrid endlinks here
you really cant go wrong with either sway bar really i guess
Silencer_0
close
- Join DateDec 2008
^ Did the powergrid endlinks make a noticeable difference in handling?
Any preference between MD and Hotchkis?Originally Posted by Gsedan35
17 post's in this thread and no one bring up what matters most. You have so many bar choices and since so many of them make questionable stiffness vs oem claims, it should come down to one thing. Bar specs, Do not bother with stiffness claims. Only one I trust is EVO350 and those specs were only made public as part of a discussion, never used as marketing. Solid construcition vs hollow. Bar strength is a fuction of diameter and lever arm distance (where you put the end link holes). In hollow bars, this applies as well in addition to wall thickness. Just because a bar set is hollow, does not mean a thinner solid bar can out leverage it.
Leverage and material rigidity are two separate concepts (e.g. a rubber replica of either bar isn't going to cut it regardless of where it attaches to the endlink). That said, I don't know of any published specs that speak to material rigidity, be it hollow or solid.Originally Posted by Gsedan35
Quote:
thats what i'd like to know as well. if you're using stock sport suspension would it make a difference? I think i read somewhere that it didnt, but could someone verify that?Originally Posted by Silencer_0
Beebo
close
- Join DateDec 2006
Quote:
what? your in the wrong threadOriginally Posted by kngofgz
any meets coming up
Silencer_0
close
- Join DateDec 2008
Hahahaha what an odd thread to ask that in.
Btw Beebo,
Btw Beebo,
