G35 & G37, Coupes & Sedans
Coupe Tires?
Old Jun 5, 2010 | 11:20 AM
AaronJP's Avatar
Coupe Tires?
About how many miles/months are you guys getting on the rears?
Mine are barely lasting a year
Barely 20k...
Any tips you guys got?
Why is this happening?
Old Jun 5, 2010 | 02:19 PM
Mustang5L5's Avatar
What tires are you buying? How is the wear pattern? Even wear? How is your alignment? Do you spin tires?
Old Jun 5, 2010 | 07:06 PM
Blue Dream's Avatar
I drove ttrank's car solo
Are you dropped is another question I'm curious about.
Old Jun 5, 2010 | 11:29 PM
G35xTurbo's Avatar
Sounds normal as far as miles go.
Old Jun 5, 2010 | 11:30 PM
G35xTurbo's Avatar
Drive easier...
Old Jun 5, 2010 | 11:32 PM
KSWAY's Avatar
If I get 20K I'd be jumping for joy..
Old Jun 5, 2010 | 11:35 PM
G35xTurbo's Avatar
Yeah, doess't seem like it would be too bad..
Old Jun 6, 2010 | 04:16 PM
AaronJP's Avatar
Maybe I was wrong like 15k.
Im not dropped, I hardley ever spin the tires, maybe one every month or 2, and for me 15-20k is about a year.
It seems that the middle is wearing out first why is this happening?
Also is it cool to mis match the rears from the front or am I asking for trouble?
Old Jun 6, 2010 | 05:17 PM
loki05's Avatar
do you keep your air pressures at the right numbers? have you gotten your car aligned correctly? toe in spec?
could be a messed up alignment or too much air pessure for starters
Old Jun 7, 2010 | 03:39 PM
onthe3rdday's Avatar
Barely 20k...
34k max on rears Goodyear Eagle RS-A's. 40psi. Like a dumb *** I autox on them.
Old Jun 7, 2010 | 04:49 PM
DailyDrivenCoupe's Avatar
i got my car with 25,500 on toyo proxes. not lowered yet but will be soon on tien s-techs. currently have 39,400 on the car and tires are still great. nowhere close to needing to be changed. at least 50% tread.
Old Jun 7, 2010 | 04:54 PM
jibberjabbers's Avatar
http://www.nissantireproblems.com/in...tire-wear.html
Email them your problems. A class action lawsuit against Nissan forced Nissan to issue a TSB on the 350z tire wear issues.
Waiting for Infiniti to step up.
You should have your compression rods/bushings checked. The original rods are known to go bad and Infiniti has issues a new "redesigned" compression rod. If the car is still under warranty I would have Infiniti replace the rods with the new revised one.
Cracked, worn out bushings can throw our alignment off.
Maybe once this is replaced with the new revised version, this would fix our tire wear issues.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
netcbc
Wheels & Tires CDN
Sep 24, 2015 09:53 AM
jjohns2711
Aug 5, 2015 08:58 AM
brian_z
Jul 29, 2015 05:08 PM
itschuckster
Jul 25, 2015 08:07 AM
