03 Coupe Passenger Window Problem
When i first bought my car, the window motor was already messing up, it would try to roll down but wouldnt roll back up. I figured the motor was an easy fix. I replaced the motor with a OEM motor and it still did not work. I replaced the window switch but that did not fix the problem, i did buy the switch used and was really beat up, so it could have been bad. I also checked and it moves in the track like butter
If i use the driver side switch to try and roll the passenger window, i hear a tick coming from the pass door.
What is the click?
Is there a relay for the door windows? If so where at?
does anybody have a wiring diagram for the doors?
Know what wires i can jump to to roll the window up and down, see if the switch is the problem?
thanks i would really like this working now its summer, more questions will come as i make progress
What is the click?
check connectors and grounds...
2004 manual located at FreshAlloy site (G35...)
(http://www.freshalloy.com/forums/sho...d.php?t=156293)
Wiring and troubleshooting is in the GW section
good luck
good luck
Micale757
Lighting
Apr 8, 2020 10:46 AM
