G35 & G37, Coupes & Sedans
Twin Supercharged???
Old Aug 6, 2010 | 10:42 AM
walshtj's Avatar
Didn't even know that was possible. Anyway here is the link, not sure how it works but its interesting.
http://www.fast-autos.net/vehicles/G...n_RS-Ultimate/
Old Aug 6, 2010 | 10:46 AM
Massios's Avatar
Anything's possible with a V and two throttle bodies.
Twin supers feeding twin turbos. It can't get any better.
Old Aug 6, 2010 | 11:12 AM
MidnightG35X's Avatar
The CCX uses twin superchargers also
Old Aug 6, 2010 | 12:50 PM
FikseGTS's Avatar
wow, $675k! not like they'll sell any of em.....
Old Aug 6, 2010 | 01:13 PM
walshtj's Avatar
Damn thats crazy
Old Aug 6, 2010 | 01:48 PM
mike5411's Avatar
I dont know why they would use twin superchargers when that engine comes with twin turbos from the factory? It just seems like they want to be "different"
Old Aug 6, 2010 | 02:03 PM
xXHotelCrazyXx's Avatar
Reminds me of a question my friend asked in tech school "Can you compress compressed air thats already been compressed?" lol
Old Aug 6, 2010 | 03:23 PM
kday's Avatar
That type of setup would be logical for low end as well as mid-range but when it comes to big numbers top end the superchargers would be more resistant because of the limited amount of boost it can carry versus the turbos.
Old Aug 6, 2010 | 03:45 PM
itgogitrev's Avatar
^^^ It's not really about a limited amount of boost. It's always a function of the heat and efficiency of an S/C vs a turbo. An S/C that is comparable to a turbo in terms of airflow will almost always make less power by virtue of parasitic loss or by the extra heat generated from the supercharger.
Either way, I would love to have a twin S/C setup for my G if I was able to fit it under the hood...
... or afford it.
BTW: Some of the older V8 Vantages from Aston Martin were twin supercharged as well.
Old Aug 6, 2010 | 04:03 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Yeah, the turbo feeding the super seems illogical. Superchargers for low end, good idea, but they are going to be matched to engine RPM, so it seems the only thing the turbos would be able to do is reduce the parasitic loss of the supercharger at higher end by reducing the work they do compressing air.
Old Aug 6, 2010 | 07:23 PM
itgogitrev's Avatar
Well, you could run a S/C that has a centrifugal clutch that disengages at a predetermined RPM and run an actuator on a wastegate on the turbo that closes up when the S/C boost falls off....
Or you can get a ball bearing turbo and anti-lag.
Old Aug 7, 2010 | 08:27 PM
nate704's Avatar
damn.....so sick!
Old Aug 7, 2010 | 08:38 PM
MTVrock's Avatar
nice... that rocks!
Old Aug 8, 2010 | 05:48 AM
I thnk you'd have a lot less trouble with a fairly straightfoward sequential turbo setup.
But this setup definitely looks cool, and would probably win the technical awards.
Old Aug 9, 2010 | 09:39 AM
walshtj's Avatar
+1, def think they did it for the technical part of the reviews.
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
