G35 & G37, Coupes & Sedans
How to use K & W coils?
Old Sep 18, 2010 | 08:41 PM
AmeRikaZmoStWaNteD's Avatar
The car i bought came with K&w coilovers. How do you lower the car using these coils? or is there something you have to do to adjust the height? Also if anyone knows how much does it drop the car. Searched but found nothing.
Old Sep 18, 2010 | 08:51 PM
G2FLIP4's Avatar
everything
Most coilovers have 2 locking nuts that can be spun down the strut shaft essentially lowering the spring perch dropping the car to the desired height. Most come with a spanner wrench to loosen the 2 nuts. The car will drop as much as how much threading on the strut shaft you have left
Old Sep 20, 2010 | 07:29 PM
red35's Avatar
Is K&W the same as KW? They have little set screws to stop the spring perch from moving. Then lower away no special trick as mentioned above.
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
DRG35R
Jan 31, 2016 07:14 AM
prinny
Nov 22, 2015 11:07 PM
Rose M
Oct 12, 2015 10:00 AM
Jeff469
Sep 25, 2015 09:28 AM
