G35 & G37, Coupes & Sedans
Can't remove insignia glue w/ goo gone, tips?
Old Feb 2, 2011 | 12:36 PM
Songle6MT's Avatar
Ahh that makes sense I guess i never thought it would do that at the time. Just figured it was like "buffing". No I have a silver car so it looks fine. My car actually was detailed by a member on here.
I will definitely use another method next time though, thank you for the information!
Old Feb 3, 2011 | 02:31 AM
c.r.harmon's Avatar
goo gone didnt work for me either... i had to use "goo gone XTREME" or something... go figure
Old Feb 4, 2011 | 02:16 AM
AustinG35's Avatar
Believe it or not, lighter fluid is amazing on tar and adhesive materials. Just wipe it on let it sit for a minute, then start to rub it back and forth. It cause the adhesive to disolve without damaging your paint. You will want to wax the area afterwards.
Old Feb 4, 2011 | 11:48 AM
gary c's Avatar
What....^....lighter fluid on a painted surface? Unless you wiped it off immediately you have no clue how much clear coat you removed. GooGone on a rag saturating the glue several times will remove the glue, no reason to go to the extreme of using lighter fluid....scary!
Gary
Old Feb 7, 2011 | 10:58 AM
theophilus's Avatar
gasoline works well.
Old Feb 7, 2011 | 12:25 PM
AustinG35's Avatar
Gary
While it does get wiped off immediately, I have never had a problem with using it in the 20+ years of owning black cars. Aside from your statement, do you have anything concrete to backup the claim that lighter fluid actually strips the clearcoat? I tried searching for this, and all I found was folks 'thinking' it might not be good for the paint, but no one giving a definitive answer. Obviously, I would prefer not strip the clear coat, but from my perspective and observing the areas that I have actually used lighter fluid, the paint on my '04 black coupe still looks brand new.
Old Feb 7, 2011 | 01:31 PM
CALex's Avatar
Use the backside of a rubber valve stem in a electric drill. This is what most of us use in the dealer when replacing emblems.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
