Part of door handle missing...!!!
How do they steel them if the bolt is on the inside of the door. I've had this happen to me twice now and I thought that is was just cause the bolt rattles loose because the 2nd time i used lock tight and I havnt had any problems.
^. I think your right I looked insside the whole on the car and the screw is there still , when it rattles it eventually comes off.... Now need to look for a DIY for removing the door panel lol
What did you do to fix this? Well how did you do it? Did you take the panel out?
Like Curryboyy said there's a screw on the side of the door. it's behind a black plastic circle cover. you pop that off and then you'll see the screw it's a star shaped one. luckily my screw was there both times so to apply the lock tight, without putting your new door lock cover in, I pushed the screw threw to you can see it where the door lock piece is supposed to go. After i applied the lock tight, pushed the screw back into the door, applied the key hole cover(missing piece) than screwed it in. Like i said i lost this piece twice and i think it was because the bolt just came loose and the key hole cover just fell out. Ever since I applied lock tight on my second one ive had no problems. Hope this helps you out.
