G35 & G37, Coupes & Sedans
Gas treatment?
Old May 10, 2011 | 09:41 AM
GRRRRR's Avatar
Gas treatment?
Hey All...
Any thoughts on using gas additives or treatments? Am considering trying some in my 04 Coupe.....Thanks!!!
Old May 10, 2011 | 10:01 AM
gary c's Avatar
I use Red Line Fuel injector cleaner every oil change which would be slightly less than 4 times a year. Most autoparts stores carry it so it's not hard to find.
Gary
Old May 11, 2011 | 12:42 PM
GRRRRR's Avatar
Gas Treatment?
Red Line....will check it out...Thanks!
Old May 11, 2011 | 02:55 PM
GR6RR's Avatar
I just drive to 76 on Citrus and pump 100 octane....
Old May 12, 2011 | 09:53 AM
gary c's Avatar
That's a waste of $$ unless you're tuned for it! And higher octane rating won't keep your injectors clean and working properly....
Gary
Old May 12, 2011 | 10:57 AM
My Key's Avatar
When you say you use it every oil change. Do you mean use it and drive around BEFORE you change your oil. Or right after you change your oil.
Old May 12, 2011 | 11:04 AM
GeeWillikers's Avatar
Walking The Fine Line...
Gary
But it sounds cool.
Old May 12, 2011 | 11:21 AM
faiz23's Avatar
I use techron additive or throw a can of seafoam in the gas tank. Any other tips out there to help with keeping the fuel system clean.
Old May 12, 2011 | 01:30 PM
dEnbOy.GFM's Avatar
Probably when he changes his oil, he adds it..
And it really doesn't matter.. It's not like oil changes affect your fuel injectors and how clean they are...
Old May 12, 2011 | 01:49 PM
My Key's Avatar
Ahh.. that's what had me confused. lol
Old May 12, 2011 | 05:18 PM
prinny's Avatar
Seafoam 100 miles or less before an oil change and then a bottle of Techron afterwards or whenever sometime after.
Old May 12, 2011 | 08:55 PM
1trueG's Avatar
BG 44k is all Ill use
Old May 12, 2011 | 09:38 PM
Infiniti Chica's Avatar
I use Seafoam, one bottle every 4-5K miles in my tank, and run it thru my vacuum line every 12-15K, but only 1/2 of the bottle.
I DO NOT put anything in my oil but good synthetics like Castrol Edge or PP Ultra with a K&N filter. I change my oil every 7-8K miles and my filter every 4-5K.
>90% of people don't know or truly understand how oil additives work, and a number of successful lawsuits against oil additive manufacturers are available to prove their ineffectiveness or potential damage to engine parts. Most car manufacturers also state that additives are not to be added to oil.
Good luck and I hope this helps.
Old May 13, 2011 | 02:15 AM
dEnbOy.GFM's Avatar
What are you talking about?? Who said anything about adding things to oil? Why would anyone add anything to oil?
Old May 13, 2011 | 06:03 AM
^^^ The question was asked if additives were placed in the oil- (to clarify a confusing post)- read the posts carefully. And for the record, hundreds of guys on the forum use Seafoam or other additives in their oil and run it for 100-200 miles just before their oil change. It's a fairly common practice, and this was what I was referencing, also.
Hope this meets with your blue ribbon standards for staying on point.
