G35 & G37, Coupes & Sedans
how much play is there on your clutch pedal?
Old Jul 30, 2011 | 02:26 PM
ihatethenoise's Avatar
I recently noticed that I have more "free play" on my clutch pedal. Before, when I try to push down the clutch with my hand, it only moves a little bit like a click unless I push really hard. Now it goes down at least an inch easily. Just wondering how much free play do you guys have on the clutch pedal? I might be using the term wrong, but by "free play" I don't mean the distance between clutch fully pushed in and the friction point. I'm just talking about how much your clutch pedal goes down if you just press on it lightly.
My mechanic found a TSB on the ball pivot for the clutch fork. It might be the cause. Also he said there's a special tool to take apart and service the clutch assembly that only Infiniti dealers have. Is this true?
Thanks in advance.
Old Aug 1, 2011 | 11:58 AM
gary c's Avatar
I think what you're referring to is the engagement point, the distance from the floor to the point where the clutch is engaged. Actually this varies between cars, you can take two of the same identical cars and the point where the clutch engages will be different....rarely the same. My last '92 TT 300ZX engaged 2+" from the floor and about 2" from the top. Hope this helps and answers your question....Gary
Old Aug 1, 2011 | 01:06 PM
WhosUrBuddiee's Avatar
I dont have a clutch.
Old Aug 1, 2011 | 07:50 PM
c_morse's Avatar
I have about a half inch of free play in my clutch pedal, and it gets worse (it seems like) on hot days. I wouldn't recommend starting with the pivot ball on the clutch fork though. I'd start with the Clutch Master Cylinder.
From what reading I've done, that seems to be the best thing to start with replacing.
Old Aug 1, 2011 | 09:35 PM
rdeverett's Avatar
Mine also gets worse on hot days. When the free play increases, so does the pedal's stickiness. I replaced my clutch fluid with DOT4 fluid but when I got my transmission replaced under warranty, I think the dealer may have replaced it with DOT3 fluid since the sticky clutch problem is getting worse out of the blue.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
AL8782
Oct 3, 2015 10:26 AM
jbmw002
Sep 10, 2015 12:54 AM
