G35 & G37, Coupes & Sedans
Squealing/Squeaking Noise
Old Aug 25, 2011 | 12:01 AM
Pangyzzle's Avatar
Recently I've noticed a squealing/squeaking noise coming from the driver side of the car. I am not sure if it is inside or outside because I only hear it when the car is in motion on the street or on the freeway. It sounds like something is loose. I am thinking the belt but when I sit in the car and listen, it sounds as if it is coming from behind the driver seat on the left side. It only happens when its in motion on the freeway and about 80% of the time on the streets. Any suggestions? Thanks
Old Aug 25, 2011 | 08:38 AM
gary c's Avatar
There's only two things that make a noise like what you're describing, belts because sound will travel or compression rod bearings which also squeak.
Gary
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
