G35 & G37, Coupes & Sedans
ahoy! on the verge of switching to the dark(light?) side.
Old Aug 31, 2011 | 10:39 PM
BuckeyeInMI's Avatar
Originally Posted by koobaru
I see, thanks for that clarification. Well, as much as I'd love the xS, I'm just not ballin enough for one. I'm going to try for an 05 I think.
There are some slight differences between 05 and 06. Most of the 05 models got new, larger brakes, but the 05x retained the 03-04 brakes. Both brake setups are outstanding, among the very best on a production vehicle (60-0 in 113 ft). The old setup does it with grippier pads that wear out quicker, wear out rotors quicker, and produce a fair amount of brake dust. The newer setup does it with larger rotors and twin-piston calipers up front.
All the 06's have the larger brakes, including the x. And the 06's also got bluetooth. Some of us with the 05x have upgraded to the larger 05+ brake setup (as it's called here). It's a (mostly) simple bolt-on upgrade. You can often find the larger setup for sale in the Marketplace ($300-ish for a complete setup). If you want an AWD, think about getting an 06 and save yourself the hassle. If you want a RWD, the only difference is bluetooth.
11bEMT
May 27, 2022 03:13 PM
wonderizm
Sep 24, 2015 03:09 AM
Ednica87
Sep 5, 2015 02:59 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
