G35 & G37, Coupes & Sedans
Need some help...Problem with lock
Old Nov 2, 2011 | 02:58 PM
deen416's Avatar
I am having a problem with my driver side lock and am not sure what to do about it...
When I use my fob, sometimes my drivers side will lock and sometimes it won't. When it locks, it will never unlock when using the fob. I used to be able to insert the key into the door and unlock it manually but for whatever reason now when I put the key in the lock it won't turn. When my driver side locks the only way I can unlock it is to open the passenger side door and unlock it from the inside which is getting very annoying.
I know the lock actuator failing is a common problem with these cars, but it is troublesome to me that the actual lock mechanism isn't turning when I insert the key into the door.
Any suggestions?
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
G35-R
Nov 7, 2015 01:21 PM
douglas555
Sep 10, 2015 04:48 PM
johnadlertech
Accessories
Sep 8, 2015 11:57 AM
